He said SC62, not SC63. The SC62 is designed to take both protected and unprotected cells up to 69mm long. The Orbtronic battery he is talking about is less the 69mm long so it should fit fine as long as it isn't overly thick.NO, the length would most likely be to long, unprotected cells only. Their website states battery length up to 69mm long.
I want to use protected battery, do you guys know what Hi capacity battery can fit in?
That's funny because I have seen many people use all different types of protected cells in this light without issue as long as they are within the specs. I use several different types of protected cells in my H600's(same specs) all the time as well without issue.I looked up the SC62, not SC63. I own this particular light and all the protected cells I have will not fit without damaging the light or denting the battery. Mechanical stresses are bad news, for both the light and battery.
True. I think even Selfbuilt said in his review that all the protected cells he had fit.That's funny because I have seen many people use all different types of protected cells in this light without issue as long as they are within the specs. I use several different types of protected cells in my H600's(same specs) all the time as well without issue.
The Orbtronic's are pushing the limits of the specs with their lengths but, still should work.
Protected cells offer many other protection features other then voltage cutoff including overheating protection, over current protection, short circuit protection, over charge protection, and often come with a more conservative cutoff voltage then ZL's 2.7V. They also offer a second layer of protection should the lights electronics fail, offer short circuit protection when the cell is out of the light, and offer added protection while charging. Although some users can safely use unprotected cells, protected cells are still the safest choice overall and it is the users choice to decide which they want to use.Why do you want to use a protected battery? Zebralight already has voltage cutoff incorporated into their design.
Protected cells offer many other protection features other then voltage cutoff including overheating protection, short circuit protection, over charge protection, and often come with a more conservative cutoff voltage then ZL's 2.7V. They also offer a second layer of protection should the lights electronics fail, offer short circuit protection when the cell is out of the light, and offer added protection while charging. Although some users can safely use unprotected cells, protected cells are still the safest choice overall and it is the users choice to decide which they want to use.
Let's not get into a debate on whether you think the OPer needs to use protected cells. He has already said he wants to and it's his choice.
Because I want more protection! And I don't want to relay on the light alone incase it's low voltage cutoff fails then I don't have to worry about it..
Here we are, perfect example! Misunderstanding what "protection" means in "protected cell." It doesn't protect YOU at all, only the cell. Thanks Nichia! for driving the point home.
Sorry, Tachead... with all due respect, but as usual, you go too far. ZL also has built in thermal protection. A quality charger is more important than a protected cell, safety wise. If your charger is overcharging your cells, I wouldn't put too much faith in a protection strip... what? A protection strip can't fail? Oh, they can, with the slightest amount of abuse. Don't use a crap charger, then no worries about overcharge.
Show me the protected cell that is more conservative than the 2.7V cutoff of ZL, please.
ICR protected cells may in fact be far less safe than unprotected IMR cells. ICR Li-ion is inherently less safe than IMR chem cells. Protected cells also have lower amp ratings, won't allow as high a current as unprotected.
The biggest problem with protected cells is that the novice misunderstands what "protected" means. They will assume the protection is for humans, when it is for the cell. This misunderstanding can cause issues, namely, a false sense of security.
There is a fine line between redundency and superfluousness.
Here's a syllogism for ya: superfluous protection is superfluous.
I was going to add, "more" isn't always more...or better...or safer.
There is no substitute for proper li-ion safety
