I have had an idea to setup the ARC4 (brightness levels, modes etc.) with a computer.
Currently the setting is done by repeatedly pressing the tail switch.
As I understand, and that is the questionable point with my idea, the tail switch only transmits the signal to an electrical contact switch in the head.
Now, if those 2 contacts are accessible from outside, maybe with an adapter that additionally provides power instead of the battery when the head is unscewed, then those contacts could be electrically connected to a switch that is controlled by a computer. Think of a relais or a parallel output signal that is swithced on an off under computer control.
Now you would need a program that controls the switch in a way that the ARC4 recognizes it as clicks to access the menus.
I think of a software that has menu entries that you could select, like "Force primary on" or "Select primary/secondary brightness level", where you could choose between 16 buttons which would represent the brightness levels.
If you want to setup your ARC, unsrew the battery compartment, screw the head onto the adapter, start your software and select the desired options. When done, your light is ready to use. No more clicking and remembering the sequences to achieve a certain goal.
What do you think of that ?
The main point with my idea is if the switch contacts are accessible.
