jtice
Please tell us about your favorite beam partern, and what light and configuration you are using to get it.
My favorite is my E1 Mod. If uses the stock reflector, with a R2K BB500.
If has a very tight hotspot, with a very wide and smooth flood.
The hotspot isnt the brightest, and doesnt throw all that much, but it makes up for it with the huge amount of lumens put out as smooth even flood.
The light will easily light up an entire room, with no need to aim the light around. But, if you want, you can aim it at an object to the small hotspot hits it to see ti better.
The Arc4 has a similar beam patern, but the E1 Mod has ALOT wider spill patern.
Makes an excellent indoor light, or for hiking at night to light up the path around your feet.
The light is so smooth due to the stippled reflector. Saddly, that also makes it alittle ineffecient.
I might as well through in a Poll, just to see what type of patern people generally like.
Please post a description explainning your vote.
Choose your Favorite Beam Patern.
