OK here is a kind of schematic picture of the guts of the ARC LS:
1--body
2--sealing gasket (kind of sticker, black)
3--lens
4--thin plastic ring - actually on the optics rim, spacer between lens and optics
5--optics
6--plastic shim
7--aluminium nut
8--aluminium nut
9--pcb board with emitter
10-aluminium nut
Sorry for the poor picture. The only CAD I have is Eagle for designing PCB's. There are no spaces between the body, sealing gasket, lens, plastic ring, optics, shim, nut actually. Nut no 7 holds everything tight against the front of the body. I did not try to show the thread in the body and on the nuts. Do not know how. No proportions as well.
As I mentioned I do not have the light with me right now. Someone else has to measure the opening of the light for you.
BTW can I have the "guts" of your flashligt if you are going to give it away? I am tempted to make my own design of some flashlight.
