Re: Any mods out there that will make a L4 dimmabl
Update.
Frangible sent me his L4, and I was able to add a dim-mode to his Z57. I'm sending it back to him today so he can use and abuse it, locating any weaknesses that were not apparent to me.
The clickie acts just like it always has, except that the lock-out function was lost due to the need to have a contact that rides on the inside of the battery tube. When the tailcap is screwed all the way down, the original parts perform all of their original functions. When you unscrew it a little, it goes into low
mode, with the current flowing through the new contact and a ~60 ohm resistor. The current supplied by the batteries is limited to about 50ma (at 6 volts should be around 1/3 watt supplied, maybe 1/4 getting to the led)
Klaus is the other beta tester. He will get his in a week or so. If both of them report that all is OK in a few weeks, I'll offer to do this for others for a fee.
This is not as elegant as McGizmos' mods. He does BEAUTIFUL work. The
parts are installed in such a way that they can be removed if desired. The light coat of epoxy that protects it can be scraped away after heating.
Daniel
