[ QUOTE ]
idleprocess said:
I believe that the TL-3 LED bezel is signifigantly larger than the TL-2 LED bezel.
[/ QUOTE ]
Yep, that's the idea. The bezel appears to be much larger in all of the pictures I've seen. The question is, (if it fits the TL-2 body), how well will the reflector work with a LUX III since it was designed for a LUX V? It's not only possible; I'd say it's probable that the TL-2 and TL-3 bodies are threaded alike because these are both mass-produced lights from the same manufacturer. They are also both TL series lights with similar body styles. It would be cheaper for Streamlight to thread them to the same specs. Does anyone know if the TL-2 LED uses a star mounted emitter?
