[ QUOTE ]
Check out flashlightreviews.com for some good pictures and info on most of the popular lights out there.
[/ QUOTE ]
Thanks, yeah, I took a look through (not every light yet though), and I didn't see much with a pocket clip. I'm guessing from the responses so far that clips aren't too common?
[ QUOTE ]
How small is small? The E1e has a clip, runs on a single 123 and is bright, even better with and LED head instead of the incandescent. Of course, the E2e is my favorite SF light, and very compact. Don't forget the E2L outdoorsman, has the LED head and a loong clip.
[/ QUOTE ]
Well, not too small. I think the E1E is in the too small category (by looks of it) I think I'd want to have a bit sticking out on both ends to make it easy to hold. I think I probably want to stick with Incandescent, I've got a led light for my bike and it doesn't illuminate inside street lamps at all (not that it matters a whole lot, but it doesn't make things any brighter) and I someone else mentioned that was a problem with LEDs. Thanks for the suggestion though.
[ QUOTE ]
Smaller? How about the Photon Freedom, really pocketable, multiple modes, and comes with a cool detachable clip you can mount to your hat or shirt.
[/ QUOTE ]
Heh, how about bigger? /ubbthreads/images/graemlins/grin.gif That does sound nifty though.
[ QUOTE ]
The TL-2 Xenon is on special at Bright Guy. Green version only for $30. That is less than one third the price of a E2. Both great lights but I have to admit I am partial to the E2 and carry it loose in my front pocket. The E2 has a truly outstanding beam.
[/ QUOTE ]
Oooh, $30 is definitely good, especially for a first choice. If I find it doesn't work quite well it's still a good light and I'll have money left over to get a different one.
[ QUOTE ]
for even more brightness you might want to check the following threads (I don't know how to post a link yet):
"The P90 with 2 rechargables thread"
"Will a TL3 bulb fit in a TL2?"
"Possible rechargeable TL3 upgrade??"
[/ QUOTE ]
You're right, I do want to check those out, I'm guessing from the fact that you mentioned them that the answer is yes?
[ QUOTE ]
(I guess you're past the PT Blast stage)
[/ QUOTE ]
Maybe? What's the PT Blast stage?
