jtr1962
Now as everyone knows summer is my least favorite season by far but at least air conditioning makes it tolerable, even if I pretty much must remain a prisoner indoors from June through September. The main two problems with AC are that you alternate between freezing and sweating depending upon whether it's own or off, and eventually the air ends up smelly despite my best efforts. Of course I keep the filter clean regularly. In addition I've tried pouring bleach in the bottom of the unit, spraying the fins with disinfectant, scraping out as much of that greenish scum that accumulates on the bottom tray as I could, and also pulling the units out once a year to give them a thorough cleaning inside. None of this really works that well. When its humid, as it usually is, you get moisture on the condenser fins. This falls into the tray, and acts as an ideal environment for foul-smelling mildew. Keeping the unit running continuously helps, but this often means bucking the AC with a ceramic heater when the room starts to get too cold. Needless to say that wastes a lot of electricity. Letting the unit cycle, especially on economy mode where the fan shuts off when the compressor does, virtually guarantees that the air will stink for a good 20 minutes or more the next time it starts.
Has anyone found a solution to this besides joining Sigman in Alaska?
As an aside, with the current state of electronics it would be very cost effective to make units which simply "throttle down" the cooling power as the setpoint temperature is reached, instead of cycling on and off. This would mean nice, steady temperatures, and probably less smell since the unit might not be condensing much water when it's throttled down. I'd like to know why aren't air conditioners made this way. Cycling seems half-assed at best. It also strains the compressor. I'd certainly be willing to pay $50 more for a unit which runs only at the needed power to hold the room temperature.
P.S. I would definitely have a summer home in Alaska if I could afford it but let's keep this thread to affordable solutions.
