I bought several of these today. (OK, I cleared them out) I am going to give them to my buddies at work to use.
The flashlight is twist-on or momentary, like an inova X1. Same circular spot, although this craftsman projects a fuzzier image of the led, due to the less pure plastic optic. With two AA batteries one might expect a brighter light. The RiverRock 2AA from Tarjay is WAY brigher, but I imagine the craftsman light would last longer on a single set of batteries.
This is a disposeable light to me. I wouldn't worry about losing it or sharing it. The threads are smooth enough, but not like the inova X1. I probably won't keep any for myself, just give em away, because I like my X1 so much more..
The flashlight comes with a nylon belt holster and 2 AA batts. I probably will keep a couple of the holsters for my inovas. Maybe I'll ask the recipients if they want theirs.
I know that the people I work with will like the focused beam. For free, who would complain? A dorcy AA light with one or 3 leds would be about the same price, but smaller and with a flood style, and might be preferrable for gifts, since the focused beam is only useful or desireable to some.
The head screws off and the pcb/led is easily removed. It is a sideways pcb ala SS1aaa light, and appears to have some epoxy painted over part of it. Not sure how to extract the lens, it may be jammed in for good. There is a white plastic reflector which the led pokes thru- I plan to glo-paint the inside by putting the brush thru the led hole.
The battery tube appears to be reversable. If you like the rubber grip one way and not the other, you can switch the head and tail. I suppose a light could be made that was two-headed with this one.
