So as part of my disaster preparedness kit, I've decided I'd like to get a couple decent flashlights in it. I carry an A2 so I think I've got most of my throw needs covered. When I was lowe's on friday I picked up a couple mag lights, a 2d and a 3d for $10 each. Not bad, I figure I can make them better than they are now. My main goal is to make at least 1, if not both, into high run time monsters with a ton of flood that I can throw some lithiums in and leave sitting forever. Something you could use for a few days in a house with no power, or in the yard to walk around. Regulated is a plus I think. Ideally at least as bright as the factory bulb. It looks like the everled might be a decent conversion there, even if its a little more than I was originally planning to spend. Anyone have any idea what the run times would be for it in either of those? Better suggestion?
How much would I have to spend to put together something that would really make my jaw drop when I took it outside and used it next to my a2? Is the 3d a good platform for that, or is that really a job for the 4d or bigger bodies. I'll probably just convert both of these to long run time models, but I might as wel start thinking up other fun things too
Thanks!
Thanks!
