Dual Bored 2P 18650 M*g 1.25D & 2S/2P 2.5D
Please read completely and carefully before you pay
Here is another creation from Fivemega. 3.7 volt, 5800mAh 1.25 M*g or 7.4 volt, 5800mAh 2.5 M*g
As you see in picture, these M*gs are shortened, rethreaded and dual bored to accept two 18650 batteries side by side and connected in PARALLEL. Using pair of AW's new 18650 cells you will get 6800mAh capacity at 3.7 volt. Excellent for P7 or SSt-50/90
Using 2 pairs of AW's new 18650 cells you will get 6800mAh capacity at 7.4 volt in 2.5D host.
Excellent for long run incands.
Outside body is partially grooved only where body has enough thickness and untouched where is bored out to fit batteries. This will prevent body weakening.
Heads are also very fine finned and flutted to manage unwanted heat.
Battery holder is integrated with switch and comes with flashlight. No external battery holder required.
Please make sure both batteries are inserted positive to switch side. Battries not included.
Side of body has charging port to recharge batteries without removing from flashlight and [SIZE=+1]NO[/SIZE] balancing required for 2P version. I will also include male charging jack and rubber plug to seal when is not used.
Any charger for 3.7V Li-ion such as this can be used for 2P version and obviously for 2S/2P version you will need this. Please balance charge all 4 cells after few pack charge.
Switch tower is machinned off and ready to install any LED module and controller.
Advantage of parallel cells are not only to save some space and double the capacity but less load per cell, less voltage drop, longer battery life, longer run time and higher current capability.
All you need to do is solder pair of wire (positive and negative) to switch and connect to controller and/or LED module.
When you hold the flashlight body horizontally, switch button is at 12:00 O'clock, one bore is at 3:00 O'clock, second bore is at 9:00 O'clock and charging port is at 6:00 O'clock.
2S/2P (with switch tower without jack) version is excellent choice for long run ROP High or 5761 (WO tower, with G6.35 socket)
This package will cost you way over what you can get here. Check it out.
Host $22
Cut, rethread $30
Dual bored $25
Outside grooves $30
Head finned/flutted $40
Switch tower cut off $15
Battery holder $30
Charging port $30
Total $222
While I charge only:
Host $22
Cut, rethread $10
Dual bored $10
Outside grooves $10
Head finned/flutted $10
Switch tower cut off $5
Battery holder $20
Charging port $10
Total $97
You will never find this kind of prices elsewhere.
Package Sale Price: $97
$8 shipping to States (Priority) for first one then add $6 for each additional.
$16 shipping to international (first class) for first one then add $8 for each additional.
For ducumentation purpose, it is [SIZE=+2]necessary[/SIZE] to post your CPF handle and detail of your order here and paypal note.
Without above information, I will never figure out what the payment is for and from whom.
Paypal: [email protected]
Please PM me for other type of payment.
For ducumentation purpose, it is necessary to post your CPF handle and detail of your order here and paypal note.
Example: NewGee :paypal: for:
#98 Red 1.25D M*g $97
Shipping to States $8
2P 18650
#01 Black 1.25D M*g $97 stub paid shipped 0309114000004628XXXX
#02 Black 1.25D M*g $97 Drywolf paid shipped 23080440000026159505
#03 Black 1.25D M*g $97 choppers paid shipped 03080730000166823270
#04 Black 1.25D M*g $97 UberLumens paid shipped 23082180000028880556
#05 Black 1.25D M*g $97 steffleu paid shipped LC547811005US
#06 Black 1.25D M*g $97 nailbender paid shipped 03092880000110388098
#07 Black 1.25D M*g $97 PhotonAddict paid shipped LC548067169US
#08 Black 1.25D M*g $97 Weld Inspector paid shipped 9505513808427191048567
#09 Black 1.25D M*g $97 n_den payment received shipped 9505513808437285099832
#10 Black 1.25D M*g $97 n_den payment received shipped 9505513808437285099832
#11 Black 1.25D M*g $97 jayrob paid shipped 9505513808438163151857
#01 Red 1.25D M*g $97 pom70 paid shipped LC845286089US
#02 Red 1.25D M*g $97 nailbender paid shipped 0309114000004634XXXX
#03 Red 1.25D M*g $97 Drywolf paid shipped 2308218000002886XXXX
#04 Red 1.25D M*g $97 nickg paid shipped LC845286628US
#05 Red 1.25D M*g $97 CKOD paid shipped 03092880000110413738
#06 Red 1.25D M*g $97 nailbender paid shipped 03092880000110388098
#07 Red 1.25D M*g $97 Scharrlatan paid shipped LC548067040
#08 Red 1.25D M*g $97 X_Marine paid shipped 23082180000028854083
#09 Red 1.25D M*g $97 X_Marine paid shipped 23082180000028854083
#01 Blue 1.25D M*g $97 3rdrock paid shipped 0309114000004627XXXX
#02 Blue 1.25D M*g $97 Drywolf paid shipped 2308044000002615XXXX
#03 Blue 1.25D M*g $97 Gino paid shipped 0308073000016681XXXX
#04 Blue 1.25D M*g $97 flashfiend paid shipped 03092880000110435228
#05 Blue 1.25D M*g $97 Jay T paid shipped 03092880000110446538
#06 Blue 1.25D M*g $97 sbelyo paid shipped 03080730000166837161
#01 Pewter 1.25D M*g $97 nailbender paid shipped 2308044000002617XXXX
#02 Pewter 1.25D M*g $97 nailbender paid shipped 2308044000002617XXXX
#03 Pewter 1.25D M*g $97 pom70 paid shipped LC845286013US
#04 Pewter 1.25D M*g $97 LightJunk paid shipped LC845286044US
#05 Pewter 1.25D M*g $97 n_den paid shipped 2308044000002615XXXX
#06 Pewter 1.25D M*g $97 n_den paid shipped 2308044000002615XXXX
#07 Pewter 1.25D M*g $97 erlon paid shipped 2308218000002886XXXX
#08 Pewter 1.25D M*g $97 nailbender paid shipped 2308218000002886XXXX
2S/2P 18650
#01 Black 2.5D M*g $97 FlaCracker paid shipped 03101230000057516172
#01 Black 2.5D M*g (NO HEAD) $67 Rommul paid shipped 03112550000058020996
#02 Black 2.5D M*g (NO HEAD) $67 (AVAILABLE)
#03 Black 2.5D M*g (NO HEAD) $67 (AVAILABLE)
#01 Red 2.5D M*g $97 Luke-299 paid shipped LC547920172US
#02 Red 2.5D M*g $97 (AVAILABLE)
#01 Red 2.5D M*g (NO HEAD) $67 (AVAILABLE)
#02 Red 2.5D M*g (NO HEAD) $67 (AVAILABLE)
#03 Red 2.5D M*g (NO HEAD) $67 (AVAILABLE)
#01 Blue 2.5D M*g $97 J3004 paid shipped LC138287972US
#01 Pewter 2.5D M*g $97 nailbender paid shipped 0309288000011043XXXX
#02 Pewter 2.5D M*g $97 Colonel Sanders paid shipped
#03 Pewter 2.5D M*g $97 spencer paid shipped LC740355964US
2S/2P 18650 With Swith Tower Without Jack
#01 Black 2.5D M*g $97 (W/S Tower WO Jack) 325addict paid shipped LC138287884US
#02 Black 2.5D M*g $97 (W/S Tower WO Jack) 357mag1 paid shipped
#01 Red 2.5D M*g $97 (W/S Tower WO Jack) 357mag1 paid shipped 23082180000028872360
#02 Red 2.5D M*g $97 (W/S Tower WO Jack) 357mag1 paid shipped
#03 Red 2.5D M*g $97 (W/S Tower WO Jack) monkeyboy paid shipped LC548067005US
#01 Blue 2.5D M*g $97 (W/S Tower WO Jack) 357mag1 paid shipped 23082180000028872360
#02 Blue 2.5D M*g $97 (W/S Tower WO Jack) CKOD paid shipped
#03 Blue 2.5D M*g $97 (W/S Tower WO Jack) gVp paid shipped LC458383865US
#01 Pewter 2.5D M*g $97 (W/S Tower WO Jack) Steve in SoCal paid shipped 03101230000057505701
#02 Pewter 2.5D M*g $97 (W/S Tower WO Jack) Scott B paid shipped 23082180000028848938
#03 Pewter 2.5D M*g $97 (W/S Tower WO Jack) double0thirteen paid shipped
#01 HA matte grey 2.5D M*g $107 (W/S Tower WO Jack) (AVAILABLE)
#01 Gold Plated 2.5D M*g $137 (W/S Tower WO Jack) UberLumens paid shipped 23082180000028880556
Please find link of my other products here and click on each link you are interested.
(AVAILABLE)
Please allow 7 days to ship
Host $22
Cut, rethread $30
Dual bored $25
Outside grooves $30
Battery holder $30
Charging port $30
Total $222
Host $22
Cut, rethread $10
Dual bored $10
Outside grooves $10
Battery holder $20
Charging port $10
Total $97
2P 18650
2S/2P 18650
(A V A I L A B L E)
