The 200s use the XP-G.
I hope it isn't too off topic, but I wonder if the Osram high CRI (neutral white - 4000K) LEDs might make an appearance. Henry has used Osram LEDs before and these have a CRI of >95 and appear to have lumous flux up to around 120 lumens for 800ma drive current. Voltage drop seems higher than the cree as I suppose these have a smaller die, but it might be interesting for a high CRI light.
http://catalog.osram-os.com/catalogue/catalogue.do?favOid=0000000000025a3e024c0023&act=showBookmark
Agreed, I'm sure that will be fixed or a replacement boot sent, etc.Are the boots covered under warranty? I'd try contacting HDS and see if they wouldn't send you a new one.
Before this thread goes crazy...... Was the light a custom job or did you receive it directly from HDS/HDS dealer?I just recieved a Hi CRI with the XPG installed.
Besides the three foot wall shots I posted, I decided to do some outdoor shots. These are 30 feet, both at max output, with the same camera settings. As you can see the T200 has a narrower more intense beam with a much nicer tint than the Rotary. They are both new models with an XP-G R5. Quite a difference there. Is a different reflector being used in the Rotary?
HDS T200
HDS Rotary
The emitter seems too "white" colored to be a High CRI XPG to me, but this is based on the comparison to the High CRI XPG in my Armytek Predator (in relation to the cool white XPG in my HDS rotary). I'm confident in my comparison. I know pictures can be deceiving in this forum, but like I said, that is my comparison. The Predator also has a larger, deeper reflector which may have altered my perception (along with other variables that play a role in photography which I have no understanding and have not accounted for).dixemon, pardon me for asking, but I just have to make sure you know what you are talking about to be sure we are on the same wavelength. What is the tint of the light like? We talking about very warm tint? The XP-G high CRI is very warm in tint, much like an incandescent. You seeing that?
What I was thinking too. I am a photographer so I am kind of sensitive to white balancing on photos. This photo just looked too warm and if you remove the warm tint from the photo the emitter would not look as warm as it is right now. Comparing this photo to the emitter on my Malkoff M61HCRI (XP-G also), the M61HCRI's emitter definitely look warmer in color than the emitter in this already warm looking photo. That was what prompted me to ask the question above.The emitter seems too "white" colored to be a High CRI XPG to me
Recieved from HDS.
Does anyone know if the rotary blinks like the previous clickies when it's stepped down a mode due to low battery?
