sortafast said:
Ok so I have been running an XR-E in my bike light at 750mA using a Downboy converter running off of a 6v NiMH pack from another light system i have. Question is, would i gain much in the brightness department by switching to a 1000mA driver? Would it be noticeable? Or would i just wind up turning the extra 250mA into heat that i would need to get rid of?
With your modding ability, I would strongly suggest that you go have a look at Georges80's website
Website
Under the 'Products' tab, check out his bFlex driver.
This man makes 'proper drivers'. You,the user, can set the ma output. So experiment from 1200ma down. Once you have established the ma setting thats right for you, it is now possible to customize the variable intensity range within the available ma you have selected.
Then , depending on your preference, you can chose one of three UI's.
If using rechargables, you can set and adjust the minimum low voltage so you do not destroy your LI rechargeable.
The list goes on and on.
Also you have a built in micro momentary switch or you can wire up your own
to a remote location in the housing.
