DIWdiver
I'm thinking of building a new board. It would be an interface from various switch types to a load up to 10A (20A or more with heatsink)
Some of its potential uses are:
- DIY piezo switches using a cheap piezo element instead of an expensive switch
- latching circuit for piezo switches
- single and multi-mode hall interfaces
- high current PWM driver for any switch type
I'm sure forum members will come up with many other uses.
The hardware would have the following features:
- Interfacing with 1-3 switches. Switch types could be piezo, reed, mechanical, or hall effect.
- three hall sensors can be mounted on board for multi-mode rotary magnetic switch
- no heatsink required for supply voltages above 2.5V, currents to 10A
- with minimal heatsinking 15A, could go to 20A or so with better heatsink
- Switch a load to ground (FET between load and ground)
- 15 to 50 uA maximum quiescent current, depending on configuration (hall sensors are about 10 uA each)
- Quiescent current can be reduced to a few uA (FET leakage) by disconnecting power supply with a low current switch
- sized to fit in the spring groove of a Mag-D tailcap, can be ground to 1" (25.4mm) diameter
- with a Mag-C spring and insulating ring, can be installed in Mag-D with NO WIRING
- all components on one side of board. Only 0.15" (3.8mm) thick
- supply voltage 2.0V to 16V (lower and higher voltage ranges are possible)
- 120 Hz PWM dimming, 0-100% output, but gets non-linear below 3-4%, max 95% DC with no power connection
- Microchip PIC16F685 processor
- schematics and parts list provided for those who want to work on UI
- can be fitted with in-circuit programming connector
- possible to build a USB or RS-232 adapter for programming
The UI is limited only by the imagination, but I am thinking to offer the following:
Single switch:
- single mode
- three modes, hi-med-low-off
- smooth dimming, touch for on/off, hold for up/down.
Three switch:
- primarily intended for rotary switch with hall sensors on board
- can be cycled in either direction
- three modes, high-med-low-off
- four modes, high-med-low-moonlight-off
I haven't yet decided whether I would release source code for everything, but some basic working UI would be released.
Pricing would be $20-30 USD.
Please reply with interest, comments, needs, and desires.
Don
Single switch:
- single mode
Three switch:
Don
