Stainless Steel Rebel 0080-Bin 5-Mode
ernsanada
I just received the Stainless Steel Rebel 0080-Bin 5-Mode from Deal Extreme
Costs $39.90.
From ordering to receiving the light took 11 days to Socal.
Fit is excellent. I give the grade A
The finish is good. It has some small scratches and some pits. Finish on the tailcap has some machining marks. I give the grade B.
Specifications from the Deal Extreme site.
- Features a Rebel 0080-BIN LED emitter. The tint on my light has "creme" color tint.
- 5-Mode Forward Clicky (mometary on when half pressed): :Hi > Mid > Lo > SOS > Strobe. Does not remember the last setting the light was on.The clickie is on the hard side to push.
- Input: 0.7V~3V (1 x 1.2V/1.5V AAA battery recommended).
- Tempered Glass Lens + Aluminum Reflector. GITD front o-ring.
- Comes with a removable clip for easy carry-around.
Rebel 0080-Bin
Rear of the Rebel Module has a hard plastic o-ring.
Size comparsions
Left to right, Stainless Steel Rebel 0080-Bin 5-Mode. Lumapower Avenger Rebel 100, Tiablo A1 Rebel 100, Fenix LOD Q4
I also took lux readings of the lights shown above. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using Energizer Nimh AAA Rechargeable Batteries, 850mAh which were fully charged.
Stainless Steel Rebel 0080-Bin 5-Mode - 380 lux @ 1 meter (High)
Stainless Steel Rebel 0080-Bin 5-Mode - 150 lux @ 1 meter (Medium)
Stainless Steel Rebel 0080-Bin 5-Mode - 80 lux @ 1 meter (Low)
Lumapower Avenger Rebel 100 - 240 lux @ 1 meter
Tiablo A1 Rebel 100 - 430 lux @ 1 meter
Fenix LOD Q4 - 400 lux @ 1 meter
Stainless Steel Rebel 0080-Bin 5-Mode @ 1 meter
Lumapower Avenger Rebel 100 @ 1 meter
Tiablo A1 Rebel 100 @ 1 meter
Fenix LOD Q4 @ 1 meter
Left, Stainless Steel Rebel 0080-Bin 5-Mode. Right, Lumapower Avenger Rebel 100 @ 1 meter
Left, Stainless Steel Rebel 0080-Bin 5-Mode. Right, Tiablo A1 Rebel 100 @ 1 meter
Left, Stainless Steel Rebel 0080-Bin 5-Mode. Right, Fenix LOD Q4 @ 1 meter
Left, Stainless Steel Rebel 0080-Bin 5-Mode. Right, Lumapower Avenger Rebel 100 @ 1 meter Stepped down exposure
Left, Stainless Steel Rebel 0080-Bin 5-Mode. Right, Tiablo A1 Rebel 100 @ 1 meter Stepped down exposure
greenstuffs
Banned
Norman, OK
Does it come with a black rubber boot? The orange one is a deal killer. Otherwise very nice! Hope they make it with the Rb 100 version. How sturdy is the clip?
ernsanada
Comes with the orange boot. No black boot.
Clip doesn't seem to sturdy. I put the light in my pocket t-shirt and if you bend forward the light will come out. I don't think if you bend the clip more it will help. Part of the problem is the weight of the light. It's very heavy for an AAA light.
mayo
Oklahoma
Thanks for a wonderful review as usual. This one sure got my attention, just didn't pull the trigger. I'm a little surprised it's that bright. Would love to see some runtimes. Sure it pretty.
RainerWahnsinn
Germany
Thank you for review and pictures. You also know the SS C3 very well, is the steel same kind of quality and mm?
Rainer
Jay T
Did anyone notice that the back of the module looks just like the one in the Tiablo A1
Fusion_m8
Melbourne, Australia.
Hi Ernie:
does it only need momentary on the tailcap to change modes or does it need to be pressed in fully for a click to change modes?
Thanks.
Patriot
Arizona
It looks like a very nice light although a bit long. It's seems like nothing can ever dethrone the LOD in the light output department.
ernsanada
You're right about the LOD.
The LOD can take the 10440's.
The SS AAA max voltage is Input: 0.7V~3V (1 x 1.2V/1.5V AAA battery recommended). I guess somebody can try a 10440 and see.
ernsanada
This is back of the Rebel Module.
ernsanada
I just completed a runtime test.
I used a fully charged Energizer Nimh AAA Rechargeable Battery, 850mAh.
7 minutes 40 seconds to 50% Brightness.
psyrens
EARTH
Wow! Thanks for the nice review.
Actually I ordered one. It's good to know that I made a good choice.
A few more questions.
Does it use PWM? Does it regulate its brightness?
