I am told 18500s are the same length as a C battery. Can I then use 2 18500s in my LED Maglite? I would make a spacer to compensate for the smaller diameter of the batteries.
Being the ML25LT is designed specifically for 2 alkaline batteries. I would say you definitely can't run it on 8+v.
I don't know anything about mags after the incan bulbs. Being that it has high/low, do they use a driver of some sort. Too much voltage will kill the driver or led depending on how they work.. however xxo said it can be run on a single li-ion, that's probably pushing it's limits.
According to the site, you can run 2 eneloops but performance will vary from using 2 alkalines.i don't have experience, so i don't know what the difference would be.
If you want to experiment with the risk of killing your light, you could try 2 li-ion and see if it quits working. I think the recommendation of a 21700 is your best bet if you want runtime, otherwise an 18650 should do
You could also run 2 of the nihm c cells which gives you 20000+ mah but they are super expensive. I had to buy 4 for an old fluke meter recently, cost was something like $70. I only buy powerex nihm or eneloop (pro)
I tried two 18500's in it. It actually lasted about 30 seconds with them then went supernova bright with a pop sound and that was that.
I have an ML25 parts light.
How come?
The one that replaced it runs fine with adapted eneloops.
Well there's the answer for the op, figured it was too much.
It would be interesting to see actual runtime graphs between c cell alkaline, c cell nihm, eneloops, and 18650 for this light (or current version). Runtime graphs like i do for the Malkoff community.
I'll have to keep this in mind.
Hahaha hilarious Bykfixer.
21700s with capacities topping 4000mAh would be awesome for this light if we can be sure that the circuit wouldn't die prematurely.
I have done some informal (no graphs) run time tests on the original single mode ML25 2C and 3C lights, both seem to run pretty much flat out with no step down and run time seems to follow the Watt-hours of the cells fairly closely, except with the 2C it dies fairly suddenly when the batteries no longer have enough power to run the light through the boost circuit and the 3C has a longer drop off as it goes into direct drive.
One thing that I found out about the single mode 2C is that it will run on a single 1.2 V Eneloop.
The new 2 mode 2C will not run on a single 1.2-1.5 V cell and seems to have a step down to extend run time.
