M-Zeppelin M6 triple MC-E mod using MZP7-3 sink
LED Zeppelin
Great Lakes
I built a 3X MC-E Surefire M6 LED mod using the sink originally designed for a tri-P7 configuration. Details of the sink are here.
Hardware:
- MZP7-3 sink, unmodified
- (3) MC-E M WD in series, each with dies wired in parallel
- (3) cut McR27XR (same as used for the P7 build)
- Shark Buck 3A
- Remora
Details:
- Vf of string = 9.8V @ 2.8A
- Regulated LED currents are 0.4, 1.0, and 2.8A on lo, med, hi
- At 11.1V, light draws .35, .89, and 2.4A on lo, med, hi
- Light can run on 11.1V - 25V or 3-6 li-ion cells
Camera @ ISO200, white balance sunshine, F4 starting with 1/8, 1/30, then 1/125 sec.
Both lights running 6 X CR123 in FM holder, 18V. Tri-P7 is DSWOJ, Shark Buck 3A/Remora.
< lux @ 1.5m = 5200
< lux @ 1.5m = 4300
For proper focus, the reflectors needed to be raised 0.007". To acheive this I used 2 layers of 0.005" double sided thermal tape on the angled reflector seats.
The gap between the bottom of the reflector and the LED base is about 0.090", so some light is escaping underneath. Even so it compares favorable to the tri-P7 version, with more throw and a defined spot. There is no donut in the beam at all.
nailbender
North Carolina
Awesome Dennis as always. I was wondering if it could not be done. Honest opinion which do you like the best.
dave
Edwood
SoCal
Looks great, Dennis. :thumbsup:
So the 3x MC-E doesn't go into direct drive like the P7's do? Looks like the MC-E is a better solution, unless you want more of a flood light, although the MZOX-4 seems better suited to the sheer wall of light task.
Hopefully those new Ostar SMT 4 die LED's will be available for you to play with in the future. Although, if I get my hands on some, they will be. ;)
-Ed
LED Zeppelin
Great Lakes
dave
Dave, I like the MC-E version, but some of that has to do with the tint. The P7s seem to have tint gradients within the beam whereas the MC-E is uniform. The P7 is a much easier build though.
-Ed
Ed, the MC-E version will also go into DD. It will behave almost identically to the P7. For the beamshots I ran both lights on 18V to be sure they were in regulation.
maxspeeds
Oahu, Hawaii
This is a work of art, Dennis! :twothumbs I am so happy you were able to tame the mc-e's hotspot. I still have an X in the middle of mines :grin2: This looks like a great alternative to your triple P7 build (actually, a superior one when distance is needed).
petrev
SW England
Super COOL
Funny - but I had never seen comparison shots of the actual emitters before ! The MCE are much smaller than I expected ! ! ! Simple photos don't show the differences well - these show that they are really very different beasts so now I understand why they are so different in use. Thanks for that too.
I think the yellow-ring colour cast problem with the P7 is down to the area of yellow base around the emitters. The MCE don't have it and later Cree XRE have dispensed with the yellow surround as well.
Good looking beam LZ - worth all the pain of the more difficult assembly I'd say.
Cheers
Pete
nleahcim
So how are you heatsinking the P7 version? I mean - it looked like you wired the LEDs in series and tied the slugs to your heatsink - but aren't the slugs tied to the P7 anode? So aren't you creating a short there?
Also, for the MCE version, are you mounting the LEDs directly to the heatsink? No PCB? Did you just bend up the surface mount leads of the MCE and solder to them directly?
petrev
SW England
Hi LZ
Anims ! ! !
1. Zoom 108% + Rotate 5.5
2. X-Fade
2. Just Swap
GIFs do lose some of the subtleties but you get the idea !
Thanks to LZ
Pete
ps. Lovely bit of Epoxy Alignment Soldering Wiring
:thumbsup:
Not to mention the coolest HS ever ! ! !
LED Zeppelin
Great Lakes
Pete, once again than you for the anims!
nleahcim, the anodizing is an electrical insulator and the main reason for the process.
The MC-E are indeed epoxied right to the sink. I did not bend the leads up as they have sufficient clearance as is. I did pre-tin the tops of leads before epoxying the loose emitters to the sink. I used just enough epoxy to ooze out but not interfere with the leads. Once the epoxy cured I shaped my wires and pre-tinned them as well. When I was satisfied with the fit, I held the wire in place and applied heat to it, which flowed to the LED leads. I checked each die with my power supply, and touched up any that weren't lighting. It wasn't too difficult, but notice I oriented the MC-Es so I could shape the leads and fit my soldering tip comfortably.
bluecrow76
Tiger Town
Very nice! I like the hotspot of the MC-E version for better throw. I would love to see an outdoor distance shot comparing the P7 vs. MC-E.
I just splurged on a Megalennium host. Hopefully I'll be able to afford one of your sinks later this year! :sssh:
maxspeeds
Oahu, Hawaii
Dennis,
I have a quick question regarding your cut down McR-27xr reflectors. Do you know (now that they are shortened) if they can fit in an Aleph1 head with an mc-e light engine (or any aleph light engine for that matter)?
Cheers!
Joel
LED Zeppelin
Great Lakes
Joel,
I don't know if they'll fit, but they are 0.95" dia, 0.61" tall.
They would need to be spaced off the MC-E as well.
I have a hunch that the standard McR27L is a good fit with the MC-E. if you had a head for that reflector I think you'd be all set. I'd guess that if you shaved off 0.010" from the back, and enlarged the hole slightly, you'd have a nice beam. The back of the reflector would rest on the MC-E housing.
LED Zeppelin
Great Lakes
Thanks guys.
Here are some beamshots. Beamshots taken at ISO200, F3.5, 1.6 sec, white balance sunshine. Lights were aimed at the upside down red canoe.
First up is the subject MZMC-3 module running 6 X RCR123 in the FM holder, 22.2V.
Next a reference MZP7-3, DSWOJ, same Shark Buck 3A and cell configuration.
Last is a reference stock M6 with MN21 running 6 X CR123, 9.2V.
maxspeeds
Oahu, Hawaii
Love the beamshots, Dennis:D! The tripple MC-E is a winner in my eyes. What type of runtime is to be expected off the 6xRCR123 cells? I'm guessing they're running 2s3p with 8.4volts and 2250mAH capacity (asssuming each RCR123 has a 750mAH capacity). 3A on high would make it 45 minutes to drain to 0% capacity, so maybe 35 minutes to keep the cells alive? Does this sound about right?:popcorn:
LED Zeppelin
Great Lakes
Joel, the RCR123 are in series, 22.2V, and draining at about 1.5A. So assuming 750mAH cells, runtime on hi would be about 30 minutes.
