deadrx7conv
I have just received this eBay bike light. Its definitely lighter and a tad smaller than the 10w VisionX/Magnalight Solstice.
I just don't see how this light will stay cool enough when pushing 27w. It does get hot pretty quickly. Will have to time it to see when the thermal sensor shuts it off.
Its all aluminum except for the metal bracket. The rear heat sink unscrews. Will need to replace the steel bracket with a copper or aluminum L-bracket so that it'll conduct heat away from the light and onto whatever I bolt it to(maybe thats what the wanna-be engineers were thinking....bicycle frame=big heat sink).
Was going to use it above the garage to light a parking spot. Not sure if it'll survive being on 12hrs every night. Light is also a little spotty for me. Settings are low, medium, high, strobe, and SOS.
The LEDs have 3 dice each. So, each die gets 3watts for a total of 9w per LED and 27w total on high. They look like 20mm stars so upgrading to XP-G, MC-E, SST50, P7 LEDs looks easy enough. I just don't think the housing is big/heavy enough for anything over 10w.
Once I get the time, I'll pull it apart for some current/voltage readings and to see how its all wired.
Want to use it as a 'fixed light'. Not sure if it'll survive being cooked at 27w all the time.
