Sometimes there is so much talk I feel that I might as well join in and tell you what I know:
I have recently built a little 12V spotlight out of 3 SST-90s driven at full power (9A). The light is focused with 3 30mm aspherics.
The throw is useable up to 300m and the width of the square is about 80m wide.
Actually I made it for a friend who wants a to shoot kangaroos at a range of 400m. At that distance you really need it to be very low humidity to work.
My experiments with aspherics, XR-Es and SST-90s have shown me that for a given aspheric, the SST-90 will shine a beam with intensity (measured by a cheap DX Lux meter) about 75% (+/- 5%) of what an XR-E would produce. Of course the SST-90 is consuming 9x as much current and the projected die is 9x the area. NB: I used top bin LEDs in both cases.
So if you have an aspheric + XR-E combination that will shine 300m, then 2 SST-90s behind 2 of the same type of lens will give you about 50% more intensity at the same range.
I like using 3 in series because it make driving them (from a 12V vehicle) easy. So I'm getting about 230% more intensity than the XR-E at any range. These numbers were calculated, but they seem about right when I take out my XR-E aspherics to compare.
The extra thing about the triple SST-90 is that the side spill is great. There is no doubt that it is a thrower, since almost all the light it puts out is in a tiny angle, but the 5% that is lost out to the sides is probably about 300-400 lm. What's more, there are no funny rings. It's all very smooth flood with a very intense, square hotspot.
So two thumbs up for the SST-90 aspheric in my mind.:thumbsup::thumbsup:
