there's a feel good factor when you mechanically wind up that film and even better when u actually get some really good shots...no photoshop!
Good shots from what? Dropping film off at a lab and having a minimum wage teenager make all the density/color corrections for you so you don't have to think? The vast majority of film that is shot today is scanned and printed. Good luck even finding a lab that still uses analog optical gear for printing, and if they did, the quality would suck anyways like it always has. I used to work with about half a million dollar's worth of the best film repro gear on the market, knew how to use it, and a digital printer and camera puts that stuff to shame.
Scanning film typically requires this thing called a computer and likely Photoshop if you are a professional.
Just try to find a digital camera with 30+ bit depth at a reasonable price.
Typical stuff said by digital luddites when they don't have a clue what those numbers mean.
I used to *only* scan my film on my 48-bit howetek drum at work, and I'll take an entry level dLSR over that
48-bit Howtek and 35mm film anyday. My Howtek cost $40,000, and a decent dedicated 35mm film scanner about the same as an entry level dSLR.
The reason film scanners require all the additional bit depth is due to the D/A conversion while trying to eat through film dye, and 30bits is pretty low end for a film scanner.
Also, what really doesn't make sense is a film scanner *IS* a digital camera. Taking a digital sample of an analog copy (film) of the original scene is illogical and produces a worse result than taking a digital sample of the original scene in the first place.
The majority of pro neg films on the market are still in use because the
elderly wedding photogs still shooting it need the +12 stop lattitude range because they can't shoot right (lab fixes messes for them).
Kodachrome nostalgia is my favorite. Here's a film that was never released in larger formats because pros didn't want it, it doesn't scan for beans and doesn't print really well, and Kodak's insistance on making their E-6 films look like it cost them most of their professional market share in the 80's and 90's to Fuji. Trust me, most Kodak shareholders wish Kodachrome and K-14 was killed off 30 years ago:twothumbs
The only thing I agree with you guys on is that classic 35mm film dSLRs are better ergonomically than current dSLRs. I had an F3 when I free lance for the local paper, and other than a D3 or 5D that old F3 was a better machine that any <$2000 dSLR on the market. I then moved on and realized that 35mm was just a
convenient, amatuer format anyways and the quality sucked compared to legitimate MF and LF formats. I'm also more concerned about how the final image looks and how I can share it rather than how good a shutter feels.
