1)Most likely.
2)I don't know, WA has a re-rater, but it will depend on your specific bulb what its performance will be.
In favour of it, I have a 6v 20w mr11 bulb plugged into a 3s (~12.4v) 20c pack. Very bright, very white.
Against it, I've also had a 6v d26 lamp assembly poof on 2s LiFePo (6.6v). Very dark, very sad.
Am I correct to presume your bulb was meant to be run from a dc converter plugged into an AC source? If so it actually takes 6v @2.5A. (as opposed to a 6v bulb meant to be run on primary cells that quickly sag well below this.) If your bulb was mean for long runs actually at 6v, it should have some capacity for over-voltage.
*Soft-start always helps prolong bulb life, especially when hotwiring (over-volting it)
