KevinL
Occasionally I get tired of carrying the Big Stick (4D ROP) around, even though runtime is awesome and the light output is, in a nutshell, stunning. For those who haven't heard, the ROP is a Pelican Big D SLA bulb in a 4D Maglite. 6V 24W overdriven like crazy, 7.2V (8.4V peak) high-current Sub-C stick. Runtime ~50min.
So I'm looking for a way to put it on a diet, and I think I've found that way.
Take ROP front end, reflector, borofloat etc.etc.etc. and place in 2C Maglite. Stuff two 18650 lithium ions in the back with a nominal 2200maH rating. This will only discharge them at slightly below 2C, which is safe for lithium ions. Light and go. ~25 minute runtime, 1/4th the weight, same output.
I've considered other candidates such as the WA1111, but it doesn't seem to deliver the same barn burning performance as the Pelican 24W bulb. Every time I look around, it keeps coming back to the same thing - the Pelican 24W delivers the best performance in its voltage class for the amount of power it draws.
The advantage of a 1111-based design is that I get to use the Kiu bipin socket, supposedly realizing an efficiency increase, but others tell me that the MagC switch is substantially more robust than the MagD switch and the efficiency gains are not as considerable.
What do you guys think? It should be pretty darn sweet to fire up the ROP in a lithium configuration that's light enough to wear on a belt
