Size and dimensions of the Predator. Easy and customizable UI via USB-port. Via computer and account on the ArmyTek website, you can change your UI. Log in, select your light, website detects flashlight and then you can customize the UI like you want to. No twisting and clicking needed. XM-L2 led, Smooth reflector, IP68, (real)thick body and head, led on copper, optional extension for 2x 18650 or 4x CR123, red blinking indicator(which you can turn off) to locate rear clicky switch, min 0.01 - max 1100 lumens.
It would be really cool to see a flashlight like a predator pro, where programming is done not through the light itself but by connecting it to a computer and programming through a user friendly software.
And made in the USA would be nice. :twothumbs
If we are going into that, I will point out that the Armytek factory is in China. In my experience, Armytek's fit and finish is definitely better than some of the Chinese companies...but ALL of the actual production is in China. Just a matter of staying on top of things, and demanding quality. China is certainly capable of making excellent products...in some areas, their manufacturing abilities are second to none.
Expanding on the whole PC software/cell phone app programmable light theme: wouldn't it be amazing if the flexibility was limitless? Like a light where you could completely choose how many modes, the output of each mode, how to get into the modes, etc. Essentially, you could have a flashlight with a single output on max. Or you could take the exact same light and give it 5 evenly spaced modes + strobe, then choose how each mode is accessed. This kind of flexibility would be amazing, especially since many people have different needs, and sometimes we want to use the same flashlight but for a different scenario. Some people like really basic lights with one or 2 modes, others like a whole host of output modes.
On another note, I'd love a headlamp like the armytek wizard pro that has a quick release feature, allowing you to easily remove the light from the head strap so it can conveniently turn into a handheld light then it can be snapped back into the headstrap on the go. Also a headstrap where the top piece can be easily removed or added.
The whole "made in USA" thing is really counter-productive, and comes from people who clearly don't understand how trade works.....
If you buy an overpriced made in US product (just because of patriotism), all you're doing is making yourself poorer, and making your economy less competitive.
Dear friends!
No matter where you use your flashlight, you just want it to be reliable. So you understand the value of a good quality light in times of need. Armytek Team is gathering information about the most important factors while choosing a flashlight.
Describe a flashlight of your dream!
P.S. After a discussion we will make an infographics including the main features of a perfect flashlight that you can use during your work, hobbies or other every day activities!
The ability to program without lighting candles, chanting, sacrificing small animals... Via USB after downloading your program, allowed by entering the light's serial number, or something like TnC's flashing screen with the tailcap by it would be great. I'm all for the ability to adjust in the field, on the fly, etc. but some have become way too complex. And heaven forbid you own more than one manufacturer's lights that can be programmed on the go! I need a book on how to use the book sometimes.
I'm okay with complex programming, and I want to be able to do it using only the light. I don't want to have to rely on a computer to program it.
I'm probably only going to program it once, so needing documentation to do it is okay. Once it is set up the way I want it, there's no need to reprogram it.
What's wrong with USB or Removable SD as an option plus "the old way?" Have both?
If you leave the battery out long enough, thought the Predators lost programming? Mine has.
