I'm bumping this thread because I ordered the airless tires and after 14 months (!) they finally came.
These are what I ordered, customized with the maximum 175 psi option. While I consider the customer service totally unsatisfactory so far I'm pretty impressed with the tires. While I'll undoubtedly have further comments as I get more experience, here's my take after the first ~250 miles:
Ride quality: At first the ride seemed somewhat harsh. I literally felt every imperfection in the road. However, the tires started to feel smoother a few days later. Perhaps the material flexing broke in much as a new shoe takes time to break in before it's comfortable. Whatever the reason, at this point the tires aren't horribly worse than pneumatics as far as ride quality goes. On smooth roads they're great. On potholed roads they're rough but then so are 110 psi pneumatics. They certainly sound noisier over bumps so they may give the impression of riding much harder than they really do. I don't find significantly more shock transmitted through the handlebars than I did with pneumatics.
Traction: When I was putting together my bike I noticed that I could slide the front wheel on a vinyl tile floor. I attributed this to the mold release. Just as a precaution, I removed the excess material along the seam with a utility knife. This increased the traction. On the road traction is as good as any air tire, and should only get better as the tire picks up road grit. I feel perfectly safe on these tires, even riding in rush hour traffic.
Fit and ease of mounting: The tires went on fairly easily, and perfectly fit my rims. I highly doubt the tires will roll off no matter what I do.
Rolling resistance: Just as I noted regarding ride quality, I'd say these tires need to break in for a few hundred miles at least to realize their ultimate potential. After only about 50 miles rolling resistance decreased notably. Also note that these tires required the skewers to be tighter in order to keep the wheels from shifting over hard bumps. Prior to tightening the skewers the wheel moved enough to cause the brakes to slightly rub. I wonder how many others this happened to and they attributed the increased rolling resistance to the tire instead of the brake rubbing? Anyway, since the rims and drivetrain are new on this bike and need to be broken in, I can't say for sure how the rolling resistance compares to pneumatics. After about 120 miles the bike was about 1.5 mph slower but a good portion of this could easily be attributable to the wheel bearings still breaking in as well as the chain/ratchet mechanism/bottom bracket still being stiff compared to my other bike. Now after 250 miles the rolling resistance seems to be even less. I really do think the airless tires have a somewhat long break-in period before they develop their minimal rolling resistance. Maybe the extra psi option does help rolling resistance considerably also compared to the stock psi. As the tires wear into the optimum shape from riding I'm sure this will help the rolling resistance even more. One thing to note which I mentioned earlier was that pneumatics more or less double in rolling resistance going from 80°F down to 40°F while the airless tires either decrease or stay the same (honestly, it seems so far they stay the same although others have said they roll better at lower speeds. Regardless, at some temperature airless tires will be as good or better than pneumatics. Although such tests are inherently difficult, I've roughly estimated the Crr of my airless tires to be in the 0.008 area. This isn't that much worse than even the best pneumatics, and right around where many touring tires are. And it's better than most MTB tires or heavy, flat-resistant tires.
So here's the overal grading comparing to pneumatics:
Ride quality:
Airless: B+ (slightly harsh over smaller bumps but not overly so, no squishy feel like pneumatics)
Pneumatics: A- (pretty smooth overall but sometimes "squishy" when you rise in the saddle)
Traction:
Airless: A
Pneumatics: A
No significant differences here
Airless: B+ (kind of a pain to mount but fit perfectly, must choose tire size matched to your rim width)
Pneumatics: A- (more forgiving of rim width and usually easy to mount)
Rolling resistance:
Airless: B+ (somewhat to significantly more than pneumatics depending upon tire choice, high rebound material solves these problems but not available for all tire sizes)
Pneumatics: A- (can be as low as Crr 0.004 but rolling resistance increases at low temperatures and depends upon keeping the tire properly inflated)
Ease of use:
Airless: A+ (no maintenance whatsoever once tire is mounted)
Pneumatics: B (requires occasionally topping off for optimal performance)
Flat resistance:
Airless: A+ (by definition you can't get flats)
Pneumatics: C (note this is based on my own personal experience, while methods exist to lessen flats they ALL increase weight or rolling resistance, and you still need to keep the tire properly inflated).
Weight:
Airless: A- (while my tires aren't any heavier than comparable air tires some models are)
Pneumatics: A
Lifespan:
Airless: A (by most accounts the model tire I bought will last at least 8,000 miles, some with the new high-rebound material have
lasted over 27,000 miles)
Pneumatics: B (most tires last 3000 miles or less unless they have a heavy, high-rolling resistance tread)
Rim Protection:
Airless: B+
Pneumatics: B+
Despite what others have said, after 250 miles my wheels are still perfectly true and undented. However, I'll grant that over a really severe pothole I will get rim damage but then again I'll also get it with pneumatics. Hence my grade of B+ for both.
Really, the only issues with airless tires at this point are higher rolling resistance for some models and in some cases a slightly harsher ride. They match or exceed pneumatics in every other area.
Other than the horrid customer service there are no show stoppers to using these tires. From what I read you'll get much better customer service ordering the tires directly from the manufacturer (nu-teck.com) rather than airfreetires.com but you will pay more. I can only hope by the time these tires are worn out that there will be an even greater selection of these tires, and that the 700c narrow tires will be available in the new high-rebound material. A high pressure high-rebound tire would have less rolling resistance than most air tires.
