DM51
Yes, I could live with that, and it's a good point about the incan being too bright to stare at. The UV would only be for occasional use anyway, and I would set mine on white most of the time.
Atomic_Chicken said:Greetings!
I've made a note on your order to support rechargeables (up to 8.5V).
As for the photo, you're the 2nd person who's asked me this week for a photo... so I'll repeat what I told him. My digital camera does not take very good Macro closeup shots, they turn out kind of blurry. I've taken a few shots of the Aviatrix mods from normal distances, but they don't show the level of detail that I'd like and I wasn't very happy with them. . . . .
Best wishes,
Bawko
Looking forward to it, js – sounds like it is going to be a little more detailed than this rather brief effort:-js said:Also, when I get my two Aviatrices I will be doing a full blown review, complete with pictures.
DM51 said:Looking forward to it, js – sounds like it is going to be a little more detailed than this rather brief effort:-
https://www.candlepowerforums.com/threads/107943
JJH said:Big Chicken,
I have restrained myself (with chains) from being in the first wave of Aviatrix buyers 'cause I am not sure which ring I want---either all white, or 1 red-2 white. I am wondering how much tint the red adds to the white when all 3 are lit, as I want 1 led mode that is all white (with as little blue as possible).
Now, since you're talking about either having 1 or 2 leds lit and not all 3, maybe that would be a better solution.
For now, what does the beam look like with 1 red & 2 white leds lit?
In awe,
JJ
Bernhard said:Is the circuit able to support current required for 3 SMJLED (5 dies, 100mA typical each, total for 3 LED will be 300mA)?
I'm thinking to get 2 mode ring and mounted 3 SMJLED on it, so I still can get low level of light as per original SF ring, and have option of higher LED light output for floodlight. I can mount the LED myself, as long as the circuit support the current required.
DM51 said:A bump for the Bird…
We briefly discussed the possibility of a 4-stage Aviatrix with RGB LEDs (each colour individually, and all 3 to make white) but as you said, the difficulty is in finding properly balanced LEDs to achieve white. I know you are still thinking about how to solve this. Would it be any easier to get the balance right with Yellow, Magenta and Cyan LEDs instead of RGB? You would get the primary colors by having any two on (C+M=B, C+Y=G, M+Y=R) so the advantage would be brighter primaries, and again all 3 on to get white. Might that work?
luigi said:Bawko,
Short and to the point: "Me wants!"
Any expected delivery date?
Luigi
To simulate a black (K) LED, you would need to install a totally inert component, or perhaps a LED that had burned out and emitted absolutely no light of any type whatsoever. Or you could just leave a hole there, painted black.Atomic_Chicken said:From my understanding, the colors red, green, and blue are used to create any color using TRANSMISSIVE technology (where light is emitted from the item), and the colors Cyan, Magenta, and Yellow (combined with Black) are used for REFLECTIVE technology (white light reflecting off a piece of paper, etc.). I've never heard of a CMYK LED array before...
