flashy bazook
- Joined
- Jan 7, 2007
- Messages
- 1,139
No, M361 does not get 5 hours on medium..
M61L draws 300 mAh at 6V and gets 175 lumens for 5 hours.
M61LL draws 150 mAh at 6V and gets 100 lumens.
M361N draws 275 mAh on medium and gets 80 lumens. However it does not specify at what voltage. If off a single 18650 (3.7V) then it makes sense that it draws considerably higher than off 6V. It has only one cell to work with versus 2. I would like to know the drain of M361N on medium off 6V (2x123).
M361N draws only 50 mAh which is comparable to M61LLL. Thats the valuable mode. I could live with the low and high mode, skipping the medium, which is brighter than M61.
I do realize the current draw on High is 1.5 Amps versus 0.65 Amps for High on M61 at 6V. Again, is the figure for M361N at 6V or 3.7V?
This review says they got over 10 hours on medium in M361:
While in medium mode the M361 maintained steady flat regulation for over 8.5 hours. It then dropped out of regulation and continued to produce a usable amount of light well after the 11 hour mark when the test was ended.
http://flashlightguide.com/2013/05/review-malkoff-m361n-lmh-drop-in/
Well, in my database the M361 on medium is supposed to draw 270 mAh at 6 volts (close to what you have, I believe).
This will give a maximum runtime of 5.6 hours. Less if you apply the 80% factor Malkoff suggests. Not 8+ hours as the review says.
Why the discrepancy? Because the review used a 1xLi-Ion, presumably putting out fewer lumens, and not 2x123A primaries. (Or, if you do the wattage calculation, with the Li-Ion used being on the very high side of capacity at 3,400 mAh, even with more similar lumens, the Li-Ion higher capacity explains the longer runtime).
So the efficiency comparison I gave and mbw_51 gave stands -- the M361 on medium is not as efficient as the single mode drop-ins at similar lumen outputs, it's worse by at least 3 hours (for M60LL) or even more (for M61LL which is a bit more efficient than the M60LL in terms of runtime/lumen).
But all your other points on the pluses of the M361 are very good points, and I think also other points regarding the single drop-ins are quite interesting and deserve a lot of consideration.
On what is an adequate amount of lumens for outdoors, it is an interesting question. I first like to go back to the original EDS (ancestor of HDS) which was quite the amazing innovation when it hit 60 lumens. This was considered quite good to use outdoors.
At some point I got a Fenix TK (not sure of the number after the TK, maybe 11?) dual mode with 60 lumens on low and around 200 lumens on high. I found I was quite happy to use the low mode when walking outdoors, although occasionally I benefited a lot by blasting out the 200 lumens to be able to see further away.
So for "near" outdoors the 60 lumens (and hence the M361 on medium, or M61LL, or M60LL) are quite fine, but you do appreciate a bigger blast (or now, the optics giving bigger lux) for "far" outdoors.
