If yours is the larger turbohead style, there are none that fit at this time. But don't despair....you can order the smaller bezel from Pacific Tactical Solutions at a very reasonable price, and that opens up the world of Lumens Factory bulbs to you (PTS sells Lumens Factory also, so you can save on shipping with a single order).
I have used every one of the nine volt lamps and they are all excellent. You choice depends upon your needs. Maximum output for a short period of time (ten minutes of less due to heat restrictions) or a slightly lower output full time use bulb.
