smopoim86
I recently got a megalennium with kt4 bezel and was wondering if there was a bulb brighter than the wa1185. I'm loving this thing, but more is always better. I could also do 3 a123 cells for higher amperage if i needed.
Go try the 1164 on the Megalennium with 2600mAH 18650s. Remember to use soft start switch and bleed off some voltage on the low level for a minute or so before going to high. It is way brighter than the 1185 :devil:
Runtime on HIGH should be about 30+ minutes.
How did you get the 2600mAH 18650's to work in the Megalennium?
I still can't get any 18650 to work in mine.
I'm thinking the new FM1909 would do it. I'm sure the run time is short but that 3000 lumen thing has got to be blinding. If we can just talk FM into selling the bulbs without having to buy a light.:devil:
I think your on the edge of discovering something the forum has yet to see
1185 is the brightest user tested lamp to use known for the M6, there will always be brighter ones, you may be the first to discover it
That AW's 30W looks awesome! Can I run it on 2xIMRs?Not at all the case. This is where you guys should start looking at Ictorana's graphs in this thread. For this question, look at the Lux vs. Voltage graphs in categories 1, 2 & 4. People forget about many bulbs, including AW's 30W.
Then you need to deliver the voltage/amps in that package size.
Would fit this bulb in KT4 considering the size its bulb opening or need to remove the bezel?
Thanks in advance! :thumbsup:
Some questions:
What about FM1909 on 3xIMRs in FM Megallenium body?
