The Duracell AAA battery leaked inside my Arc AAA and left a crust in the bottom of the Arc AAA. What do I need to do to clean out the inside of the Arc AAA?
If you have a hand drill, wrap some steel wool around a drill bit and polish the crud out at slow speed and be careful not to let the drill bit touch the bottom, just the steel wool.
nyyanks
I would try using something less abrasive, maybe poor some windex or alcohol in the tube and let it sit awhile then use a Qtip or microfiber towel and twist it in the tube till the residue is gone.
