Batteries in a radio...
donn_
Great South Bay, LINY
My blackout radio calls for 9 volts from 6x Alkaline C cells.
is there any downside to running it on 6x NiMH cells for 7.2V, or from 2x AW Li-Ion C cells (with spacers) for 7.4-8V?
If it's an analog radio (needle-and-dial/not digital), it'll probably work fine with either config. Analog radios are excellent battery vampires and usually have no problem running with near-dead cells or way-off voltage.
If it's digital, it'll probably only allow the voltage to fall within a specific range, and will refuse to work outside of it.
Either way, it'll either work or it won't, so do experiment. The only downside would be notably less runtime.
It's digital. It's an old Radio Shack Realistic DX400, direct entry, AM-FM,SSB/CW.
As long as I don't run the chance of harming it, I'll experiment.
I've got 2 large boom boxes that I run on NiMH rechargeables. One is an AIWA that takes 8XD batteries and I get 10 to 12 CDs per charge, (RadioShack 4500 MaH) about what I get from alkalines. The other is a Sony that takes 6XD and it actually seems to run better and give me longer play time than alkalines.
