Justin Case
- Joined
- Mar 19, 2008
- Messages
- 3,797
I think I really want a real flood light (or even a diffuser). I expect any self defense situation to be the opposite of slow and deliberate searching. I expect the light to be used in quick flashes, rather than a constant-on sweep, and when the light is on I want to light up half of the room instantly. I want instant target recognition, even if a threat exists 50 degrees off the light's center.
You need to be careful about what you assume to be how a self defense situation will unfold. It will be what it is, not necessarily what you want it to be. Even in an in-extremis situation, your tactics can comprise both deliberate and fast clearing. If you are clearing to escape an area, for example, are you really going to just blast forward when you hear gunfire and commotion in the next unknown area ahead?
At 50 degrees off-axis, your vision is poor. What you'll see is either movement or an object that doesn't belong. A flood, IMO, isn't going to help in actual recognition until you turn your head. In that case, you can also simply turn your non-flood flashlight onto the area of interest. That said, of course you need some level of side lighting to be able to at least illuminate off-axis "stuff". IMO, a standard M60 has plenty of spill for that.
Also, you simply can't process all of the information instantaneously if you think you are going to visually inspect a large room volume at once. That's why the flood sounds good only in theory. Your solo dynamic clear ought to be a fast version of a deliberate clear, with fast pieing, etc. Taking in half a room at once means you are exposed to half the room also. It is very doubtful that you can OODA loop that volume fast enough to beat getting shot by someone who only has to watch the small volume where you are standing. It's not a foot race where the winner has the fastest time. The winner is the one who survives with the least negative impact to himself and his loved ones. If you are going to do a solo dynamic clear, you are by necessity going to have to bypass or give at most cursory attention to most areas. I assume that your envisioned mission is rescue/retrieval of a child or other loved one sleeping in a different room. Again, a flood is not going to really help.
For small areas like hallways, use bounced lighting to minimize dazzling of the vision. Don't just shine the light straight down the hall.
I can envision a benefit of a flood in terms of using it in a deceptive way to mask where the search is coming from. The brighter side spill of the flood may allow you to see the area of interest more effectively while using brief, angled bursts. But, you can do this with an M60 with a diffuser, if you need it, while retaining the longer throw capability of the M60. Of course, everything has an upside and a downside. A diffuser adds bulk and cost and you have to either flip the diffuser lens off or on, which you may forget to do (or don't have time).
