Bi-pin bulbs positioning problem...
FILIPPO
Italy
I all,
I'd like to know how do you put your bi-pin bulbs in the bulb socket...
this because I have always some problems with my mag85...I use wa1185 and wa1306 and sometimes I have to change the bulb (becouse I need more runtime or power) and I sepent about 15-20 min trying to centre the bulb in the reflector hole....this to have a good beam. using 2,5" vlop throwmaster head the beam is ugly is you don't centre the lamp inside...
anyone had some tools to do it faster?
thanks!
Here's how I do it with my Mags:
With the bulb seated, and with the bezel off, I push down on the reflector until it sits all the way down. Using a pencil eraser I gently nudge the bulb around until it looks centered in the reflector opening.
Good luck.
Gary
Even when that bulb is centered in a VLOP the beam isn't all that perfect...as I'm sure that you know.
I use the same method as Gunner except I use a small rubber wedge. I like the idea of the pencil eraser though as it seems more precise.
yeah I know but if the bulb isn't centred you'll get a balck shadow in the middle of the beam...:(
thnks for your suggestion I'll try with a pencil the next time...
