This is part II of the beamshots I took while on a trip to Brown County, Indiana a few weeks ago. These are the longer range beamshots I took using the high output lights I have. You may have seen the close/medium shots with the smaller, more pocketable lights. If not, here is that post: http://www.candlepowerforums.com/vb/showthread.php?t=191407.
Originally I was only going to include my big hitter incandescent/HID lights, but the thrower LEDs I have did so well I decided to include them also. It's not fair to compare the total light output, but you can see that the reach of these LED lights is amazing even compared to some of the powerhouses I have.
I took shots at 450' and 600', and on the way back to my cabin I took some shots of a treeline at 500'.
My camera is a Fujifilm F30 with the following settings, which get the beamshots very close to what I saw with my eyes:
- ISO 200
- 2 second exposure
- F2.8
- White balance set to daylight
Here is the line-up in order as pictured (all have new primaries or fully charged li-ions):
- Mag85 3D (SMO - Kai) (WA 1185) (3x18650)
- Mag61 2D (MOP - FM) (Philips 5761) (6xEneloop AA)
- Boxer 24W HID (3x18650)
- SureFire M6 HOLA (MN21) (6xCR123)
- DBS 3SD Q5 SMO (18650)
- Tiablo A8SE Q5 SMO (18650) (Not pictured - I only used the Tiablo in the 600' beamshot)
I ordered the beamshots in order of perceived performance from least to best instead of the order of this list.
Here is a shot of the target (roof) in daylight and a control shot showing level of darkness when I took the beamshots.
450' Ft Shots
Daylight - 450'
SureFire M6 - 450'
DBS 3SD SMO - 450'
Mag61 MOP - 450'
Mag85 SMO - 450'
Boxer 24W HID - 450'
600' Beamshots
Daylight Shot of target (roof) - 600'
Control Shot - 600'
SureFire M6 - 600'
Tiablo A8SE Q5 SMO - 600'
DBS 3SD SMO - 600'
Mag61 MOP - 600'
Mag85 SMO - 600'
Boxer 24W HID - 600'
I also wanted to take a few a longer distance treeline shots, so I found a good place as I was heading back to the cabin. There is a pretty big drop-off on this hill, and it's about 500' to the trees. Unfortunately I didn't get a daylight shot of this.
500' Beamshots
Control Shot of target (Treeline)
DBS 3SD SMO - 500'
SureFire M6 - 500'
Mag61 MOP - 500'
Mag85 SMO - 500'
Boxer 24W HID - 500'
My conclusions - I give the win to the 1800 lumen WE Boxer 24W. The Mag85 is very close and has much better color, but I give the edge to the Boxer for thowing like a maniac while illuminating a larger area around the target. Also, although the Mag85 keeps up very well and seems to match it, the Boxer is doing all that with an OP reflector vs. the smooth reflector in the Mag85. I can't even imagine how far the Boxer would throw with an SMO reflector. But the biggest edge the Boxer has is it's practicality - 60 minutes of regulated 1800 lumen output in a light I can stick in a holster on my belt. I actually took this light with me on a long night hike, and it was awesome. Surprisingly, it wasn't too bright to use for a hike, and it light up an unbelievably broad area. It was like taking a day hike in the dead of night. Not to mention all the batteries that were saved, since everyone else I was with could turn their lights off when I had it on...
The M6 is an awesome light, but it diffuses too much over these distances. The M6 is amazing for medium ranges up to 300'-400'. However, at 500', I put the M6 ahead of the DBS due to how much better the M6 lit up the surrounding area. The DBS had a stronger spot, but it was confined to such a small area that it would be poor for searching an outdoor area at that distance. The M6 did as well as it did I believe due to the color rendering.
I was dissappointed at the Mag61. I had heard that it was even brighter than the Mag85, but even with a tailcap mod and FM adapter and Eneloops, it just keeps up with the M6. But, at least it's rechargeable...
Finally - I have to give a shout out to the awesome LED throwers at 600'. Here we have lights at the fraction of the competetor's size that you can stick in your pocket, runs for 3x as long on 1/3 of the batteries, and throws with the big boys. Way to go Dereelight and Tiablo!!
Thanks for checking this out, and thanks to all those that put up with my many modding questions in getting these built, as well as those that persuaded me to get the awesome Boxer! Great purchase!!
- Rich
- ISO 200
- 2 second exposure
- F2.8
450' Ft Shots
Daylight - 450'
SureFire M6 - 450'
DBS 3SD SMO - 450'
Mag61 MOP - 450'
Mag85 SMO - 450'
600' Beamshots
Control Shot - 600'
SureFire M6 - 600'
DBS 3SD SMO - 600'
Mag61 MOP - 600'
Mag85 SMO - 600'
500' Beamshots
DBS 3SD SMO - 500'
SureFire M6 - 500'
Mag61 MOP - 500'
Mag85 SMO - 500'
- Rich
