blasterman
- Joined
- Jul 17, 2008
- Messages
- 1,802
The past month or so I've been losing a lot of Cree XR-Es on the test bench, and have been banging my head trying to figure out what the problem is. I now have suspicion what it is, but would like some advice from some others here before I approach LedSupply on the issue. I want to make sure I've ruled out every other possibility.
A couple months ago I bought a 350mA LighTech driver from LedSupply. The driver, has worked fine in the arrays I've built, but it seems to be the culprit behind my high death rate of Crees, but it's not consistent.
Originally I thought I was doing something wrong, but after yet another XR-E died half a second after I pulled it out of the shipping box I noticed the common thread. Previously to using the driver I opted for 12volt supplies and power resistors, and I've never lost an LED that way...provided I remembered to use the right series of resistors. However, *every* Cree I've lost has been *only* when connected to the LightTech driver, and they always die within a few seconds of being connected to it. There's a brief '*spark*, and the LED refuses to light again.
What made the trouble-shooting even tougher is that I've hooked the LighTech up to an even larger variety of 3Watt BestHongKong ProLights, Luxeon IIIs, and K2's. *None* of them have died - it's only Crees, and only certain ones. Today I got Red K2 and a Blue Cree XR-E to test. The K2 fired up fine with the LighTech. The Cree sparked and died within a fraction of a second.
WTF? Am I supposed to use power resistor with a 350mA dedicated driver on a XR-E? Seriously. What am I missing here.
Taking all the variables into account, the common culprit is the LighTech combined with Crees, and this includes Warm-Whites, Neutral White's and Blues. I've never lost a Cree using 12-volt supplies with proper resistors, and the LighTech has never 'popped' another brand of 3-watt LED. When connected with several in series, the LighTech has never 'popped' a Cree.
This leads me to initially conclude (and realize I'm a novice when it comes to electronics) the LighTech driver is either defective, and/or when is initially connected to a single Cree isn't regulated correctly, or quickly enough.
I have to also conclude there's enough deviation with XR-Es themselves that some are more resistant to the problem given I have several R2's and Warm-Whites that work just fine with the LighTech.
Is there anything structural with XR-Es that would make them more delicate with the Driver?
Should I assume the driver is defective even though it powers up other LED types just fine?
