Erasmus said:I wouldn't really recommend them. I had a testing sample and it was really hard to get it focussed well. I also received a prototype of a new 1.5 degree lens which worked absolutely flawless. It's strange to see this lens hasn't made production yet since I got it last summer. Maybe you can ask Carclo when they are available for retail.
Fantastic job GANP, very nice work:goodjob:! These 1.5 deg' are available from whom Erasmus?:huh:Ganp said:Hi Erasmus ... did you build this 1.5 deg' optic into anything?
Any photo's or beamshots would be interesting.
Colin.
Ganp said:Welcome to CPF gresgate.
IMH the Carclo 2 degree optic is best with a Luxeon lll for throw and even better if it is modified a bit.
It does not focus Cree XR-E's or Seoul P4's well. It can be modified to focus them better, but wastes the extra lumens in untidy side spill.
Some of my efforts with it are here and here.
Colin.
BPH said:Ganp,
Sorry if I missed it, but have you used the Seoul P4 with the 2 degree yet?
I saw your post and link for the CREE, but didn't see info for the Seoul?
As you likely know, the Seoul has a lambertian pattern more similar to the Lux, unlike the Cree.
-BPH
gresgate said:This I received from the Carclo representative:
"Can you explain to me the beam output needed as the 10025( 2 degree optic) will give you a spot of light with a hole in the middle that close up and the spot will be 50mm dia. Are you looking to get as much light in the smallest spot?"
I think this uneven pattern of light is normal for this optic.
Sorry not responding before, well it's a medical device that need to feed the maximum light power to a fiber optic bundle inside a cilinder of aproximately 0.7 inch deep and 0.3inch diameter.Ganp said:How close up do you need to be?
Colin.
