Hi,
I have a project, which is a desktop lamp using many small leds. The lam pdoes not need to be very bright, it will be used for ambiance or to watch TV in a not completely-dark room. I *guess* that something around 300-600 lumen would be fine (similar to a 40-50W incandescent bulb). Cold white or warm white would be nice. Pure white would be to hospital-like :)
The lamp was originally designed to use flexible-pcb SMD led strip. but after some calculation, the given flux is certainly over rated. If we can get 30 lumen per watt from them, 10.5V and 20mA per 3-leds would give 126 lumen per meter, which means less than 200 lumen for the lamp (1400mm of led strip, 60 leds per meter on standard 5meter rolls).
Of course there are other options, like 90 leds per meter strip, or 5050 leds instead of 3528, which would give twice the luminosity. So I searched the forum for information, and came across the "5mm LED fade testing continued" which makes me wonder if the chinese $25 5 meter led reels are good solutions.
Another option would be to include copper wire in the designe of the lamp, and directly soler solder SMD leds on the copper wire instead of user led strips. So the problem would be to find leds which are :
-About 5 lumen each
-Slightly warm white or slightly blue, not pure white
-Long lasting
-Not to hard to source
-Wide angle
Looking at Osram website, I found LW E6SG (3.5 lumen), and LUW E6SG (4.9 lumen), but at $1 + shipping on digikey, it is not in my budget.
Does someone have an idea so I can finish the lamp before christmas ?
Thanks you,
jaune.
-About 5 lumen each
-Long lasting
-Wide angle
Thanks you,
jaune.
