Help!
I'm trying to design a compact head torch.
From the front of the lens to the rear of the emitter, needs to be roughly 2". The slimmer the better.
The lamp is to be a thrower. I'm looking at using a P7 or MC-E.
I would like to use a lens to give a beam angle of around 2 degrees.
I have a number of questions:
1/ Where does the emitter need to be placed in relation to the focal length in order to obtain a focussed image of the die at infinity? (IIRC that's the definition of focal length, but schoolboy physics was a looong time ago, so just checking!)
2/ If I fix the focus of the torch at infinity, what will the beam look like when the illuminated object is closer than infinity.
3/ How do I calculate the image size, or beam angle given typical lens parameters? (diameter and focal length seem to be all you get.)
4/ I could use a mirror at 45 degrees to mount the LED at right angles to the lens, shortening the overall system fron to back. Can anyone recommend a supplier of mirrors? What problems might I encounter?
5/ Should I use a reflector on the LED to direct more light onto the lens? Will htis affect 2/ & 3/ ?
I'm sure the answers to these questions will raise yet more questions, but this will certainly help for now.
Many thanks for your time and patience.
