balou
hi,
this design was floating around my head, and then I just had to draw a preliminary sketch in eaglecad. basically it's an ultra-thin (1.6mm, 0.06in) credit-card sized, wallet-conformant flashlight with a very wide beam and an output of guesstimated 24'000mcd
specs:
powered by 4x cr2016 lithium coin cells, two in series. powering 4 samsung 3-chip smd leds.
the base for the whole thing is a 1.6mm pcb, with holes drilled for the coin cells and the leds. contact to the coin cells can be made with a small strip of aluminium or copper foil. as a substitute for top and bottom plates I thought about using pda screen protector foils. they are tough and just a tenth of a mm or so thick. some sort of print-on stickers could also be used, to make a business card with an integrated flashlight.
the switch is a momentary SMD switch by omron which is just 1.3mm thick. btw, the switch is the little thingy on the right. it's sunk in a bit, to make accidental activation in the wallet a bit harder
here's a pic of the led mounting method:
and here's the rough pcb layout:
LEDs: http://www.led-tech.de/de/Leuchtdioden/SMD-LEDs/Samsung-Ultrabright-SMD-3-Chip-LT-1323_1_2.html
SMD switch: http://uk.farnell.com/omron-electro...p/tactile-switch-side-actuated-smd/dp/1333655
so... any comments whatsoever welcome. is there already such a light? (I know there are some which contain a 5mm led and lr44 batteries. obviously they're not really 'credit-card sized'). do you think that such a thin light is a stupid idea? 😉
specs:
