Cree Beamshot judgment
Am I expecting too much?
  • Yes, looks acceptable
    Votes: 21 70.0%
  • No, should be better
    Votes: 3 10.0%
  • Hmm, borderline. depends on the person
    Votes: 6 20.0%
  • Total voters
    30
f22shift
Singapore, NY,SH,BJ
I'm not sure if I am crazy or not.
Do you think this beamshot would be acceptable for a cree light. $50's range.
Review shots from light reviews. yeah i know the exposures will be different in the beamshot.
edit: oops, obviously i think the beamshot is one sided because the emitter is misaligned. the light reviews has an aligned emitter which obviously makes the even beamshot imo.
both of those seem to be close to the wall.. the lower shot is pretty clean but I bet the spot softens up alot after 8-10 feet.
it's hard to tell reflector depth, what light is it?
Just judging by looking at that picture it looks very acceptable to me.
The ones that I don't care for is when you have a bright hot spot surrounded by a dark ring, then a bright ring. I think this one is just fine, even for a white wall hunting mission!
You guys gotta cut back on the white wall hunting. Looks just fine to me. I have never seen any corona when using a light to see in the dark. Now if the tint was very very bad that could be an issue. The tint seems good so just roll with the rest.
Also the gap shown in green is nothing to worry about. Your eyes must be good as I would have never picked it out. I say enjoy the light. :)
Take it outside and see if you can notice in during actual real world use. White wall beam shots are good to show the characteristics of a beam, but small issues with the beam on a white wall often won't be relevant in real world use. Unless you can see it in actual use, to the point it's distracting and being a problem, I wouldn't worry about it.
perfectly acceptable in my book. The slight off-center / non-symmetric appearance will wash out when used illuminating non-white wall surfaces.
that's what i want!:eek:
i'm officially crazy then. :tinfoil:
i need some time off of cpf..
i'm in the minority here.... i go white wall hunting every chance i get and i dislike rings though they do not effect the usefulness of the light.
You're actually not though. It's just that the only ones really vocal about it are the ones that claim to never look at white walls, and then clamor for white wall beamshots.
Everyone looks at white walls as it's a good way to get an idea how a light will perform and whether you'll have any dark spots in the woods when you shine your light out there.
