Hey all,
I love my D10 but intermittent issues with the piston drive was annoying me. I would clean the ring of the piston that makes contact with the brass ring every now and then but the problem got worse over time. It's been less than a year since I got the light.
I disassembled the light and I found the issue. Tarnished underside of the brass ring that makes contact with the circuit board and the outer edge of the circuit board itself is also tarnished. I had no way of seeing this until I decided to bust her open.
Here is the underside of the brass ring that makes contact with the circuit board when the piston is pressed down. Note the tarnished area.
Below is the circuit board that the ring sits on top of. Also tarnished.
I know electrical contacts will tarnish over time but this is a bit much.
I tried to clean the brass ring with alcohol, didn't work. I just scraped it gently with a knife and it got pretty clean.
I tried the alcohol then the knife with the circuit board but now that part of the board is not Gold colored anymore:ohgeez:
The light seems to work ok now but if this happens again I'm not gonna be happy.
So design flaw or I just got unlucky?
Sorry for the poor pics...just bad lighting.
Ajay
Ajay
