bridaw
- Joined
- Feb 22, 2007
- Messages
- 38
I recently purchased some lamp assemblies from the Lumens Factory to convert several surefires to rechargeable and make my shotgun forend brighter.
I purchased a HO-6 to replace the P60 in my 618FA shotgun forend. Did I end up getting essentially the same lamp? I recently read a thread about how various manufacturers rate their LAs and a tip about comparing run times instead of lumens when comparing different brand LAs. I originally thought the HO-6 would be about as bright as the P61 with longer run time. Am I going to be disappointed with the HO-6 and should I have purchased the EO-6 instead?
I also have one G2Z-BK-NR, one G2-YL and one C2-HA. I purchased some of AW's Protected R123A (750 mAH) batteries to drive Lumens Factory SR-9 LAs in these three lights. I know I could have gone with HO-9 but decided to play it safe and also get longer run times. The SR-9 on Protected R123A batteries should be brighter than the stock P60/123A setup right? A lot brighter? Will it be brighter than P61/123A or should I have gone with the HO-9?
Feels like I just typed another language... fancy lego light options making my head spin. I'm almost afraid to ask if I should have considered a different battery? It is a shame I can't just use the 18650 batteries I use with my RPL-300 to keep it simple.
