So to rebump this thread, I did some testing (and still do..)
As there is much discussion about the best setup for throw (and lumens output), I decided to put some things to the test.
The results are reason to start a new thread (in a few weeks..or months..) about the various collimator setups, and their effect on throw and lumens output (torchlumens).
But the thing I want to share right now: In my quest for bigger glass based TIR optics, I just made a 35mm diameter TIR. Below is the 35mm test setup with a Cree XR-E R2 (EZ1000)
And the next picture immidiately shows why so many people prefer the TIR over the aspheric lens:
Compare that to the spot of the aspheric setup: (note that differences in spot brightness are due to different camera settings!)
Now the purpose of these test setups: The big question that is asked many times: Which is better for throw, aspheric lens or TIR optic ?
I carefully created two very identical setups, one with the 51mm aspherical lens, and one with the 35mm TIR. In each setup, I used the same led, provided exactly the same current, and measured exactly at the same distance, using exactly the same lux meter (as I only have one..)
For correcting the difference in size, I recalculated the data from the asphere to the level of the 35mm TIR, and to be sure, I also used an exact diaphragm on the asphere to bring the effective apperture down to that of the 35mm TIR..
(Please note that the aspheric lens and TIR-optic I used during these tests are both uncoated.)
Here are the results: (3.6 mtr measuring distance, 750mA to led)
51mm Aspheric lens without diaphragm : 4,620 Lux (59,875 lux@1m)
35mm TIR optic : 2,020 Lux (26,179 lux@1m)
Aspheric lens 35mm diaphragm : 2,182 Lux (28,279 lux@1m)
So the aspheric lens wins !!!!???? Not so fast guyzz !! :
My 35mm TIR has a 10.5mm diameter 'refraction chamber' that does not play along until an extra collimation lens is placed, and I've not placed it yet..
So that means the overall effective surface of my 35 mm TIR is not 962 square mm as with the 35mm aspheric setup, but more like 875 square mm !!
This means that when the TIR is finished (with central lens) it will give 2,219 lux.. (28,758 lux@1m)
Conclusion: (surface recalculation included)
Aspheric lens 51mm : 29.31 lux/mm2 (@1m)
35mm TIR : 29.91 lux/mm2 (@1m)
35mm asphere (diaphragm) : 29.40 lux/mm2 (@1m)
As these results are only 2% apart, I hope you'll agree that these differences are not big enough to declare a winner! So, aspheric lenses (of decent quallity of cource) give the same throw as high quality TIR optics with the same diameter.
But almost everyone knows that TIR optics give a much nicer beam with more usefull sidespill (more lumens) and no extra colors.
The main reason why so many use aspheric lenses is that they are cheap and commonly aviable, the aviabillity of TIR optics are limited by size and material (30mm tops, acrylic based, damaged easily).
Certainly the glass based TIR optics cannot be found anywhere (correct me if I'm wrong..) I think that right now, I'm the only one that makes them..
I'm working on a 65mm diameter high quatily TIR optic right now. It will be finished next week.. I hope...
Edit: Pushing the limits, with the XR-E R2 at 2amp, I managed to reach 45,000 cp with my 35mm TIR. When recalculating, that would give like 140,000 cp with the 65mm TIR ! (DEFT killer?)
And here is a picture of the illumination of the internal surface of the 35mm TIR optic:
Now some claim that throw with a aspheric lens can be improved by adding a pre-collimator lens close to the led.. This is not true !! In a high quality setup, it only improves the overall lumens output.
When a pre-collimator lens gives better throw with an aspheric lens, the only possible conclusion would be that the aspheric lens has imperfections that are overcome by the pre-collimator lens.
In fact: Compared to a single high quality aspheric lens, a pre-collimator setup has (somewhat) less throw, caused by the reflection and absorbtion losses within the pre-collimator!
Regards,
Ra.
