Dual Luxeon K2 TFFC DD Mag 2C - lots of pics
PCC
Sitting' on the dock o' The Bay...
This is a light that I built for bigchelis. He supplied the host, batteries, emitters, and lenses. I supplied the heatsink and assembled it.
Blue 2C MagLite host
Stainless steel tailcap with shorty spring and lanyard ring/spacer
2 X Luxeon K2 TFFC emitters (forgot the tint)
2 X IMR 25500 batteries
2 X 3 degree lenses (I forgot which ones they are - bigchelis?)
This is my Sherline miniature mill. I've set it up for use as a lathe and it works pretty well in this role. It has its limitations but I've learned to work around most of them. To give you an idea of the size of this thing, the red dial on the right is about 1.25" in diameter.
I started off with a piece of 1.75" 6061 aluminum round bar. I don't have a band saw or chop saw so I got some exercise by cutting it with a hacksaw. Yes, that is my foot on the left of the picture trying to stabilize the aluminum bar.
I mount this roughly 2" long slug in the 4-jaw chuck and started to square up one side of it. This is the emitter side.
You can see the chips flying in the middle picture.
Flip it over and cut the other side to fit inside the MagLite body.
I didn't take pictures of some of the intermediate steps but you get the idea. Here's a picture of the mostly completed heatsink next to one of the reflectors and the blue 2C host that it's going into.
Test fitting the heatsink and lenses.
With the bezel and UCL in place. Yes, it's a tight fit and, yes, the bezel blocks part of the lenses. I don't know how many lumens are lost due to this but bigchelis should be able to test it this weekend and report back his findings.
I decided to drill holes underneath the contacts to run the wires through the heatsink instead of through a central hole. This increases the thermal mass of the heatsink as there isn't a large hole running through the middle of it but I had to mill a slot down one side of the narrower section to run the wires. The emitters are attached to the heatsink using Arctic Alumina thermal adhesive then the wires run and soldered to them. I cut out tiny patches of electrical tape and stuck them between the wires and the bare aluminum of the heatsink, just in case. I used thermal paste between the body of the light and the thinner section of the heatsink.
Then the lenses were installed and the bezel with the UCL.
The two holes were drilled to mount the heatsink directly to the bezel but I only used one screw. Both the heatsink and the bezel were tapped and a set screw was used so you don't see the screw head. Also, I drilled a small hole into the host through the threads for the head and stuck a short pin into it to prevent the head from turning, which would pull all the wires out. The heatsink prevents this pin from coming out.
All told I spent about 8 hours working on this light but the results are worth it. I've measured 1560mA draw at the tail cap and the batteries measured 3.85V. It puts out roughly 450-500 lumens. The spot was not as small as I thought it would be for a 3 degree optic but it's not bad. The beam has a distinct hotspot surrounded by a bright corona which is surrounded by a square (blue tint!) secondary corona. This comes from the optics and is not noticable when used outdoors. There is very little spill outside of this square box. Interestingly, the light emits some heat in the beam. Are these high CRI LEDs? My P7 MagLite does not produce any detectable heat in the beam at 500 OTF lumens.
White balance set to "sunlight", manual exposure mode, mint green painted wall at 6 feet:
1/500 sec @ f/29:
This shows the hotspot.
1/500 sec @ f/5.6:
You can see the corona and the square secondary corona around it.
1/250 sec @ f/5.6:
This is what it looks like to my eyes.
For comparison, this is my Surefire G2 with a drop-in rated at 210 OTF lumens as measured by bigchelis (ThruNite reflector, TLS TX-3 pill with XP-G) - 1/250 sec @ f/5.6:
My Surefire 9N with TLS TX-3 head and ThruNite 3-mode XP-G pill - 1/250 sec @ f/5.6:
All in all it was a very satisfying build. It'll be difficult for me to give this one to its owner... :)
PCC,
This dual K2 light is Direct Drive which is why I asked PCC for such a hugemongous heatsink. The 1.5A at the tail is via 8.4v input = 12 watts (no load). I wanted a K2 Mag build that would have some throw. Why not SST-50 or SST-90 or MC-E/P7 = K2's have tints I really like.
Here is where I purchased the K2 TFFC Optics from: Yeah I expected 50mm ones, but I got 30mm or so. They are suppose to be 2 degree optics = narrow!
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=350-2017-ND
The K2 TFFC UVOF (1.5A/300L) are the ones photophanatic sells:
http://www.photonfanatic.com/ComponentsFS.html
The Cells are actually the protected C cells DX sells. They might be cheap DX cells, but they provide more juice on high current builds then even the AW black C cells. I know I checked:whistle:
Impressive build! :thumbsup:
Now this is also interesting:
Taking on any other custom projects?
Hey nice build , cool mini mill/lathe, I'd love to have one of those in my shed!!
Just for refrance, would you mind sharing the make model nos of the mill, are they still avaiable these days or is it an old model?
PCC: Very nice work. I like the originality of your design and the innovative use of the Sherline mill.
bigchelis - Thanks! I could not remember the details about the parts that you gave me last week. You don't need this light, do you? My daughter loves the blue and she loves the output! You might have to wrestle a 9 year old to get your light back :grin2:
Thanks!
Surefire 9N LED conversion link here.
PM me what you have in mind. Keep in mind that I cannot cut threads except for what I can do with a tap and/or die.
It's a Sherline 5410 miniature mill and they're still being made. It's actually too small for most things flashlight related and you can buy a proper lathe for less money. I bought this originally for making RC car parts which are mostly small parts of no more than 4" X 4" X 2" (100 X 100 X 50mm). For example, the holes that I drilled for the LED leads were started on the mill with a really short center drill but I had to finish by hand-drilling the holes using a handheld drill. That's because the extra one inch length of the drill bit was about 3/4" too long.
Thanks everyone! Like I said, it was a fun build and I learned a few things while doing it. It has given me an opportunity to come up with some ideas for a cycling light that I want to build using the same optic.
Update:
I got the light from PCC this Sunday and its intense hotspot and brute lumens results in 27k lux at 1 meter.
The OTF lumens were measured with Laptop 18650 cells that were at 4V each. I bet they sage quite a bit, which was a good thing in this case. The OTF lumens were 585~450ish at 3 mintues. The current was 2.8A, which is way too much current for a single K2.
My next plan is to put 5.5V input = 4 CR123 NiMH Tenergy cells
Then try 7V input = 5 CR123 NiMH Tenergy cells
These K2 emitters have some freakishly scary low vF. More tests to come.
bigC
I had a shootout with another member who has an MC-E WARM Mag build. These K2's even at 2.8A each emitt a nicer warm as its more neutral like. :confused:
I would have thought overdriving these emitters this hard they would have turned angry blue, but instead I get nice warm/neutral tint that makes trees and bushes appear awesome and more realistic to sunlight.
I always like XR-E R2's for throw, but I think my new favorate emitter is the K2 TFFC's they rock:thumbsup::thumbsup::buddies::clap:
Mr. Milkyspit,
I sent you a PM regarding a potential build. Not sure if you use PM or if it is full for example so wanted to let you know out here.
