Extension for Z2
PhillyRube
I saw a post on here, about putting a 1 cell extension on a 6P or Z2, and then a different bulb. Any ideas? Searching has me fairly fried, cant find a thing.
I get my 1 cell extentions for $6 at lighthound.com.
You could even purchase 2 18650 extention and run 3 17670 cells/batteries in your light for extended runtimes. It will be about 12in long, but very long runtimes as opposed to 3 cr123 cells.
For my Incandescent lights I prefer using 3 IMR 18650 cells. Long but greater runtimes than in a Surefire 9P; especially with Turbo heads.
You can get from Lighthound a Solarforce +1 extender, turn your 6P or Z2 into a 9 volt/ 3 cell light. I ran a 6P setup with a pair of 17500 li-ions and a Lumens Factory HO-9 lamp. Good output and runtime.
Oh, I see you want to run only 2 cells. while the brightest I have is the IMR9 D26 500 lumen drop-in for Surefire 2 cell hosts. I run it with 2 18650, but 2 17500 will work too.
You could also run the P90 and P91 lamp from Surefire with 2 17500.
Here are youre options with 2 battery set-ups and their Lumen readings
Remember to get some AW 17500 protected cells. If AW made the IMR 17500 it would be better, but I didn't see them for sale at lighthound. Perhaps others may know if they exists. I only use AW IMR 16340 and IMR 18650 for my incandescent lamps.
Lumens Factor EO-9 Lamp_____272__turn on peak_______2X18650 L I_________Solarforce L2 Host 1 extension, A/r Coated glass in BZL.
Lumens Factor EO-9 Lamp_____260___warm___________2X18650 L I__________Solarforce L2 Host 1 extension, A/r Coated glass in BZL.
Lumens Factor HO-9 Lamp_____180__________________2X17500 L I__________Solarforce L2 Host 1 extension,
Lumens Factor ES-9 Lamp______100__________________2X17500 L I_________Solarforce L2 Host 1 extension,
Are the Surefire "A19" cell extenders still available? They match the gloss black 6P and Z2 finish nicely, and would let you run a P90 from 2x17500 cells.
Paladin
