[ QUOTE ]
mobile1 said:
very nice - good to see that you are maaking progress. Any ideas of the diameter this driver will have?
If there is a possibility to increase the mA to 1500, this driver would be very interesting for the upcoming K2 Led. Any chance that the production version can handle 1500mA?
[/ QUOTE ]
FatFlex is based on Fatman - so same electrical drive characteristics. 1500mA is pretty tough for a boost driver (especially a small IC with the switch elements internal). The bigger the voltage delta (in vs out), the great the input current that has to go through the switch element. Easier to do a high power buck converter. Also, at 1500mA out, the input current to a boost converter is going to be high enough to freak out small li-ion cells.
FatFlex is the same diameter as Fatman.
george.
