Walt175 said:For demonstartion purposes I ran my LOP-SE on a Li-ion at Photon Fest 7. It is impressively bright, but it gets hot FAST. Not a whole lot of heatsinking. Not something I would do on a regular basis.
Mike89 said:Don't need it, nor do I need the SE version. I kept it simple to my needs and just got the simple L0P. Powerful little simple light - twist on, twist off, without the gimmicks. I just don't particularly care for this twist on, twist off for 1 1/2 seconds, twist on, etc business. Gimme the light, let me turn it off and on, and forget all this other stuff.
Seems a way will always be found to make something simple complicated.
Yeah.. I didn't understand Mike89's explanation and problem with having a light with simple options either. :thinking: It's not complicated.NetMage said:Switching modes requires twisting faster than 1.5 secs, not waiting. It is really quite easy to switch modes by twsting quickly.
When you wait over 1.5 secs, it resets to start over with the next on/off at high.
dchao said::wow:
80 Lum in that tiny body (without much surface area to dissipate heat). Just don't get your fingers burnt!
Thujone said:Does it just drop to direct drive, or do the levels still work?
