markfinn
Got my T1 yesterday, and I'm really impressed by the quality in terms of
-optics: very clean, well centered and much better than seen on any Fenix light before
-brightness: wow! this thing is easily outshining a P3DQ5 on turbo (big difference for just 10 lumens on paper, I guess the P3DQ5 is in the minus tolerance and my T1 on plus?)
-beam quality: I can only confirm what is said here already, very nice hot spot with nice spill, bright neutral white
However, what bothers me, is the position of the clip relative to the Fenix engraving (flat area) on the tube.
If I set my T1 to general mode, the tip of the clip is half way touching the lower part of the flat area, scratching it even harder when changing to turbo.
A little difficult to describe, let me try it that way: If you hold the T1 horizontally, head pointing to the left & text readable, the clip on mine is below the Fenix T1 logo. Sooner or later the 'x' will be worn because of scratching when changing modes. On turbo it's OK, clip completely on the knurled part.
In WadeF's pictures
http://www.candlepowerforums.com/vb/showthread.php?t=181629
the clip is far away from the logo, and even when switching modes it does not come even near to that.
Is that only a problem on my T1, just a production tolerance in the position of the threads, or have others found that as well?
Besides that I don't need the clip at all, I wish it would be positioned opposite to the flat area.
Markus
In WadeF's pictures
Markus
