Hi all, this is my first time asking for advice, so please let me now if i haven't covered something, or need to improve my post. Thnx
I am looking to upgrade my flashlights.
I am trying to decide between a Fenix tk35 and PD35, and whether the additional £30 is worth it.I have searched the forums,there are mixed reviews for fenix.I noted in one thread that the Eagletac TX25C2 XM-L2 would be a better light, I hadn't previously considered other brands
Thanks in advance
==================Flashlight Recommendation Checklist================
1) How would you prefer to purchase the light?____I would like to purchase the light in person from a brick and mortar store or online. I am located in the UK
2) budget: upto £100 / $160
3) Format:_______X_I want a flashlight (hand held/self contained)
4) Size .___X_SMALL - Every day carry (4-7 inches).__X__MEDIUM -
5) Emitter/Light source:__X__LED (known for efficiency, longevity, and compactness)
6) Manufacturer:__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
7) What power source do you want to use?.__X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al) but I would like more information on power sources.
7a) N/A
8) How much genuine out the front (OTF) light do you want/need? 700 lumens minimum
__x__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
9) Flood vs Throw: __x__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
9a) Distance: How far away will you typically need to see with this light (check all that apply)__x__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
10) Runtime: .__x__90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: _x__Critical (Police, Fire, Search & Rescue, Caving, Survival
12) Switch Size, Type, and location (choose all that apply):__x__I don't know, I don't mind tail click, but do like forward clicky for ease
13) User Interface (UI) and mode selection. _x__I want multiple light levels. __x__I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
14)Material/Finish/Coating x_Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA,
15) Water resistance)_x___IPX7 (Waterproof to 1 meter/30min)
16) Storage conditions___x_Emergency kit (long standby periods)__x__Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
17) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? No thanks.
I have re-submitted this to tidy it up using a laptop rather than phone, apologies for the mess of the earlier post, its hard to see it on a small device. lesson learned.
Many thanks in advance
andy
Thanks in advance
7a) N/A
andy
