Phaethon
:laughing:Finally it's almost over. I had to source a 10-15 degree lens and have a housing from solid aluminium, machined for the setup to obtain sufficient heat dissipation. For added piece of mind, i tried using a pwm circuit (based on a 555 chip) to drive the 17.5V, 1.1 Amp led in order to reduce heat production. However, i could find a matching step up converter so it's driver by just a step up converter and 14.8v li-ion battery. Problem is that the lens provides a very wide beam with huge light diffusion :candle:. I can actually light my toes when holding the light straight forward at hip height-don't know if this helps-. It's definately not a spotlight, even with the lens that claims to be a 10-15 degree one. Temperature is ok though.I am waiting for a pcx lens to arrive, to try and get more focus from the centre, but next project will use the osram ostar 20w+ instead of the edison.
Enjoy...
Throw comparison pics to my nuwai tm-801 triple seoul p4 @ 1Amp. The bright one is the seoul
Enjoy...
