HID Bulb Question
350xfire
Texas
Guys:
I am playing around with a couple of HID automotive kits and need to know one thing:
one of the kits is 35W
the other one is 50W
I was wondering if the bulbs are 35W and 50W or if the bulbs are interchangeable from 35W to 55W ballasts? i.e. is the ballast what makes the kit 35/50W or is it the bulb or both?
Thanks
It kinda depends on what you are looking at. The Chinese kits will run the same bulb on both kits, and the ballast will just drive the bulb harder in the higher wattage kit.
The real lighting companies (like Philips) have come out with D2 style bulbs that are meant for 50w, and proper ballasts to drive them.
Since the ballasts, if generic Asian, are likely less that 55W, you'll get the best output performance from the 35W bulb. The performance of a true 50W bulb probably won't be very impressive if driven by a 40-45W ballast.
Thanks guys. They are from China. The 35W is a regular-sized ballast. The 50W is a slim ballast.
both use generic china 35W burners. Use name-brand bulbs if you are driving them at 55W in a heat-sensiive application
Thanks for all the help guys. I just fired the 35W with the 50W ballast and it is noticeably brighter. These will be used on a set of video dive lights. Another question:
The slim ballast has a black potted box attached to it that feeds the light bulb. I assume that this is how they can build a "slim" ballast. Take some of the components of the full size ballast and incorporate them in a separate box... The question is:
Is that part removeable? Is that some kind of relay for automotive use that for my dive light use I can remove? This will help me out a lot in space use if I can remove it.
Thanks again
And oh, another point... according to my power supply the 35W sucks about 4 amps at 11.1 v (44.4w), the 50W sucks 4.5 at 11.1v (49.95W). The slim ballast 50W did run about $100 vs about $40 for the 35W.
Is that part removeable? Is that some kind of relay for automotive use that for my dive light use I can remove? This will help me out a lot in space use if I can remove it?
Nope, that is the igniter, cant do it without that.
OK, that's what I thought I got to looking at it and it seemed like a high power device, not just a relay...
Last question: Do these ballasts mind running is series or parallel? I was thinking about doing a big battery canister and stuffing bothe ballasts in it with one switch and battery pack.
Just keep in mind that when a HID ballast first fires the bulb, the current draw will be higher than the hot/constant current draw. When I tested HID ballasts years ago, I was seeing around a 10A spike when you first turn them on, steadily reducing to around 3.5A constant (14.4vdc). If your batteries are not strong enough to give 20A+, you will get a heavy voltage sag or failure when you fire two ballasts at a time. Most ballasts have a specific voltage operating range, obviously if you fall below it - they will not fire.
Also consider that you will need a single switch that can handle over a 20A pulse current. Since your voltage supply is lower, you will draw more amperage. I don't know if you will find a switch that will fit your needs, so you may want to use the switch only to activate a high current relay that will feed both ballasts. Obviously the inputs need to be run in P. Be sure to properly fuse. :)
Do not run the ballast outputs in S or P. They start a cold bulb at around 18Kv and cannot (afaik) work together with another ballast in any situation at all.
Good points I had not thought about!
Thanks
Hi,
We are a HID manufacuturer and I can help you answer your question,
the bulb is definitely interchangeable but see below for the 35W and 55w difference
1.) 55w is only 15% brighter than the 33w
2.) because of this brightness, it burns out the bulb and the ballast out faster
3.) 55w is 2-3 times more expensive than the 35w
Guys:
Thanks
Hi,
Thanks
Hi,
Those numbers are very "telling" and interesting.
True 50 watt (to the bulb) is 60%-75% more light (lumens depending on the bulb used) not 15%. Your 55 watt is input watts not output and only 40-45 watts to the bulb. Also the Asian kit bulbs do not perform well either.
Using Philips, Osram or GE HID bulbs, 35 watts (true) to the bulb compared to 50 watts (true) to the bulb is 3200 lumens vs 5100-5700. The 5700 lumens is using Philips DL50/740, the 5300 is using the DL50 (Fat Boy). A 50 watts (to the bulb) over driven GE, Philips or Osram 35 watt bulb gets about 5100-5200 Lumens about 60% more lumens than a true 35 watt input.
most ballasts come in 55w, not 50w, but in certain senses lumens occur about 3200 down to 2800, the higher the Kelvin color the lower the Brightness (Lumen)
Also for those looking out for HIDs, all aftermarket HID companies DO NOT make 4300K (This number is patented) and therefore the closest color to the 4300K is 5000K that most aftermarket companies sell.
5000K is slightly lower in lumen about maybe 50-100 lumens dimmer than stock 4300K HIDs but not very visible by light.
Also please understand that since HIDs are in general 2-3 times brighter than Halogens, it is really not necessary to have 5000lumens of lights shattering in front of you to blind people and catch unwanted distractions :thumbsup:
Most cheap Asian ballasts come in "55 watt not 50 watt". None of the Asian ballasts are 50 or 55 watt output. This is marketing BS because the industry standard is output wattage rating not input. Output is what is relevant especially because of poor efficiency numbers on all or most Asian (Chinese) ballasts. The Asians all rate their higher wattage ballasts using input. Even their 35 watt (if true 35w) would be called 42 or 43 watt using this same approach. The industry standard for HID is using output wattage for the basis of rating a ballast, not input as all the Asians have been doing for about 4 years now.
5000K from a reputable source (Philips is a good example) is about 10-15% less light than the same bulb type at 4200-4300K. That is 300 to 500 lumens less. As for cheap Asian bulbs who knows what the difference would be???
Numbers cannot be patented only concepts and ideas. There is no patent on the output of 4200-4300K that is BS. Philips Osram and GE MAY have patents on the fill (blend of chemicals) to get that color but other blends (not likely as good) will get the same color.
This forum is not for car people very much, in this group more is almost always better. These guys always are looking for more light except when they want to maximize runtime (battery life).
You need to study up on your facts before you "spout off" here. Quite a number of people here (CPF) apparently know much more than you do about HID. You are likely just "parroting" what others have told you. You need to get the FACTS or you need to find a new career. Looks like you are located in Chesterbrook, PA nice location.
Guys:
Please lets not turn this into a pissing contest as to who is right or wrong. My goal with these kits is to make a pretty cheap underwater video light set up. Some of the Brightstar bulb/ballasts (35W) are $170 each with a car HID kit I can get 2 35W/50W bulbs (whatever the actual rating is doesn't really matter, these things are f'ing bright anyway) for $50-$100.
I am planning on building a delrin canister(s) for the batteries and ballast and using probably 18 18650 cells to drive each bulb (3S/6P configuration).
Now for my next challenge: How to mount the bulb in an aluminum housing without having to machine a bunch of parts to keep it in place?
Thanks for the help so far!
And yes, so far it looks like the Asian ballasts are rated on input power since there is no way input will equal output due to system losses, etc.
Hi,
Hi hidextra.com you mention ballasts burning out faster, what is it that usually fails in a ballast ? Would it be the spark gap ?
I wouldn't go so far as to say that ALL Chinese made HID kits are under driving the bulbs in such a way.
I have several kits from DDMTuning.com and they are probably the best kits I have used.
I have used the cheap magnetic ballast that can be found everywhere on ebay, rated at 35 watts. It was horrible, the bulb was so underpowered that it was always blue. The light was only slightly brighter than the stock halogen bulbs.
When I switched to the slim digital kit from DDM, the light was white (Bulbs on both kits were rated at 4500K), the arc was perfectly stable (the arc would undulate in the capsule with the larger lower output ballast, causing flickering) and current draw by the ballast seemed to change in relation to what power was required to keep the bulb current constant (where as the magnetic ballast was limited to right at 35 watts input, but the bulb current was all over the place). Also, the cheap magnetic ballast lasted a whopping two months before letting the smoke out.
I have installed their slim digital 55 watt ballast in a flashlight and it is notably brighter than the 35 watt ballast. Power draw is just over 55 watts with a claimed ballast efficiency of 97%, I am calculating a bulb wattage of right at 55 watts.
Just because most manufacturers use the same components, don't trash them all because there are some good bits out there floating around.
(Yes, I understand that retrofits are generally frowned upon and no matter what I say will change your mind on this, so flame away!)
You can do what a lot of us have been doing for a long time.. find a local body shop and ask them if you can buy one or two of the xenon headlights that have been smashed in an accident from a vehicle in the shop. Many shops will throw them away, so nearly a useless item to them. You can salvage useable parts from these even after a wreck - useful parts depend on the extent of the damage, but many times you will get good ballasts, HID bulbs, reflectors/projectors, bulb mounts, wires & connectors. This is a good way to help your project along and stay on a slim budget. The HID components that you get from most OEM's are superior quality to the Chinese stuff as well. :thumbsup:
